Seagate 6.0gb external usb drive malfuntional and can not be seen by by winXP.
    Sergeant:
  • 291 Answers
Uninstall usb software drivers, reboot, reinstall them again. If your seagate 6.0 GB is damaged, "Get back to me, I'll try to help
Posted on May 02, 2008
I pulled the seagate 2.5"
When you use external adapters to plug drives into USB ports the drive needs to be set for mast not slave. The internal drive is one one channel and external drive is on a different channel so neither drive is a slave, both are masters with not slave drive present. Try removing the jumper you installed and try the drive, it should be seen because all windows XP or later do not need drivers for USB drives.
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | Seagate Momentus 4200.2 100 GB Hard Drive
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
Looked all over my compaq and cant find my seagate 500gb xt hard drive
the hard drive even though it might be mentioned to be external is still inside the casing of the laptop and can only be seen if you open the laptop completely.
Apr 18, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Cannot power on Seagate Freeagent Desk external hard drive
Hope this has only been used for backups, and not as a primary storage. The best way to trouble shoot something like this is to purchase a USB/SATA adapter. You will need to dissemble the device and take out the hard drive. Connect it to the USB/SATA adapter to see if the drive spins up and can be seen by the PC. This will let you know if the drive is OK and whether the fault is related to the external bay electrices or the drive itself.
Good luck, you can get the USB/SATA devices quite cheap off of eBay.
Cheers,
Ripface.
Sep 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I cannot see my free agent external drive
u can see the news that the st drive has many bugs,and which cannot be detected by the pc is the most popular one,so u can update the firmware from seagate official and if still cannot repair,u can go back to me,honglake@gmail.com
Mar 15, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
