Question about Microsoft Windows XP Home Edition
The HP monitor stop working with systemax windows xp
The HP monitor stopped working with systemax windows xp. I get this error message on screen. NO VGA INPUT NO DVI INPUT Thanks, MIke
  • Anonymous Nov 25, 2008
    Computer appeared to start but I had no display on my VGA monitor. Reseated the DIMM and blew out the DIMM connector. Fixed!
    Scholar:
  • 162 Answers
Restart your computer keep tapping "F8" key from your key board after that select "Enable Vga mode"
If your computer start reinstall your computer display driver.
Posted on Nov 25, 2008
  • 89 Answers
No vga input message means that the monitor is working fine, and the problem is probably your pc. check the cable connecting the monitor to the pc. if that is ok, you ma have to open up the pc and check some components, most likely the RAM
Posted on May 02, 2008
Error on windows xp desktop page_fault_in_nonpage_area
You receive "Stop error code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA)" or "Stop error code 0x0000008E (KERNEL_MODE_EXCEPTION_NOT_HANDLED)" when you restart a Windows XP-based computer uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png954211 MS08-061: Vulnerabilities in Windows kernel could allow elevation of privilege
  • 959252 Error message when you switch the operating system from a dual monitor setting to a single monitor setting on a Windows XP-based computer or on a Windows Server 2003-based computer that has the security update 954211 installed: "Stop 0x0000008E"
  • Note Update 959252 addresses a known issue that was introduced by update 954211.uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pnguparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.png824684 Description of the standard terminology that is used to describe Microsoft software updates
    Jan 06, 2014 | HP Computers & Internet
    Error code 0x00000002
    STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
    This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
    Cause of Error:
    • You may be using corrupted profile in your system which raised this problem
    • The device driver of your system is not updated
    • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
    • Registry database of your system may have corrupted or modified erroneously by invalid application
    • You have installed new hardware unsystematic or installed unknown application
    • Spyware has infected the PC
    • Antivirus software is not working
    • The operating system or application might have run out of usable memory.
    This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
    How to Fix:
    To fix STOP 0x00000002 error you need to follow the following methods.
    • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
    • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
    • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
    Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
    Hope this information will help.
    Your response is very much appreciated. Thank you for using Fixya...
    Sep 28, 2011 | Microsoft Computers & Internet
    I have an hp pavilion tx 2000 with windows 7. and want to install windows xp. but there is an error occur. error number is stop: 0x0000007b please need help thanks alot
    This is a blue screen error associated with the registry this error should be fixed with a format and reinstall with xp if still don't work get a different copy of windows xp that doesnt have this error on the disk.
    Mar 04, 2011 | Computers & Internet
    My Hp Pavilion dv5000 crashed! XP cd displays error message!
    If you are facing this issue while installing Windows, Most probably there is an issue with the memory card. If you have two memory modules try to use one of the memory modules in each slot at a time. If you have only one memory stick then try to use it one by one on each slot. If you it does not work then probably you might have to replace the memory stick.
    Hope you find this information helpful.
    Thank you for choosing Fixya
    Dec 22, 2009 | HP Pavilion dv5000z Notebook
    My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
    hello there
    here is some information that should be able to explain this error and how to fix it ok?
    best regards michael
    1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
    2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
    3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
    Sep 16, 2009 | Microsoft Windows XP Professional With...
    Job Status Window Interface has stopped working.
    The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
    There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
    you can copy and paste the following links to download and run the files :
    Patch file to remove xp drivers:
    http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
    Driver for vista
    http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
    Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
    Screen going white computer stopping
    Update video card drivers. Start there and if that doesnt not fix problem we will move on to other things.
    Jan 13, 2009 | HP Pavilion a1130n (PX769AA) PC Desktop
    Pc does not go beyond Lsass.exe application error
    Try getting into safe mode, by taping the f7 or f8 key before it boots. Once in safe mode we can do a restore to the last restore point, and go from there. If you can't get into safe mode, let me know and we will go into the bios, set the machine to boot from the dvd drive and use your xp disk to boot her up, this method id too much to post here, let me know and we will take it up only if needed. Also try this, turn off any user accounts that the computer has installed other than your administrator account, and let me know what happens
    Dec 15, 2008 | Systemax Venture PC Desktop
    Settings for dcl lcd monitor
    Your laptop resolution is greater than the external monitor can handle. From your laptop, try changing the screen resolution to 800x600, if it works, up the ante to 1024x768. You can bring it up again until you find a comfortable screen resolution. You will eventually stop to a point when your external monitor displays about 80% of the laptop screen. That is, back to your original problem. But you get the idea. Cheers!
    Mar 27, 2008 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
    BSOD in windows XP Professional
    A stop error occurs when Windows XP Professional stops responding. Stop error messages can be caused by hardware or software malfunctions. The error messages appear on a blue or black background. The following steps, which also appear on the stop error screen, help you find out the cause of a stop error and how to fix the problem. To troubleshoot General Stop Errors: 1. Restart your PC. Unplug each new hardware device, one at a time, to see if this resolves the error. Try to run any hardware diagnostic software supplied by your computer manufacturer. 2. If this is a new installation of hardware or software, contact the manufacturer for any Windows XP Professional updates or drivers you might need. Click Get support, or find information in Windows XP newsgroups (under "Ask for assistance") and then click Get help from Microsoft in the left-hand column. 3. Check the Microsoft Hardware Compatibility List (HCL) to verify that all your hardware and drivers are compatible with Windows XP Professional. 4. If you can start Windows XP Professional, check the System Log in Event Viewer for additional error messages that might help identify the device or driver causing the problem. 5. If you cant start Windows XP Professional, try to start your computer in safe mode, and then remove or disable any newly added programs or drivers. 6. Search the Microsoft Knowledge Base for "Windows XP Professional" and the number associated with the stop error you received. Specific Stop Errors Some stop errors display descriptive messages such as "DATA_BUS_ERROR" that can help you determine the exact solution for the error. This section discusses how to troubleshoot specific stop errors, based on the type of error you receive.
    Jun 26, 2007 | Microsoft Windows XP Professional for PC
    Microsoft Windows XP Home Edition Logo
    102 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
