Water spits out from bottom when triger is not pressed
  • 172 Answers
I am not sure what a triger is, but if you are getting splashing water from underneath it can be coming from your pump, or you could have a tub seal leaking into the bearing.
A couple of other things that can cause this are when you wash on a small load the water can splash on the fins in the bottom of the wash tube and drip off the lid down the sides and onto the floor, and some models have an overflow tube that drains down to a metal pan underneath. I hope this helped you. have a nice day. Mike mca0824@aol.com
Posted on May 02, 2008
Shutter trigers automatically
Could be 2 issues:
1) trigger button dead or malfunctioning
2) some dust/filth/water in the connector port (on the left side of the device)
Apr 07, 2014 | Canon EOS 50D Digital Camera
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
How do i fit the rotary spit for eb270 built in oven
insert the support frame in the 2nd level from bottom - wiggly bit facing outwards and up. inset grilling tray on bottom level to catch fat. Heat oven, then insert end of rotary spit in hole at the back RH corner of oven (slide cover aside) balance front end on wiggly bit, unscrew handle, close door and press rotary spit key (2nd from Left bottom row)
Jan 16, 2010 | Gaggenau EB 270/271 Electric Single Oven
Acts like its got water in system spits and
pump and filter are in the fuel tank. the box you speak of could be the bottom of the trunk or a vacum canister.
Dec 29, 2009 | 2001 Dodge Durango
The tool attachment won't spray water-
you almost have to open up the unit and follow the hoses from the handle into the base.fill it with solution and turn on pull triger.hold the triger in and turn off the unit keeping the triger pulled.turn off and start it up and try again.if it don't spray you might have a bad pump.open up the unit and see if all the hoses are hooke up.there should be a plug on the handle .is it plugged in.please leave feedback.i hope i was some help to you...pet
Apr 26, 2009 | Hoover SteamVac F5914-900 SpinScrub...
GSS25L GE no water
Check the electrical connector that is next to the water pipe at the bottom of the freezer door
Aug 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Unit spitting out a water mist
Algae builds up in the tray at the bottom of the evaporator coil. There are pills for that, and a cap of bleach will do fine, but smell for a little while. Sometimes the whole unit will have to be removed outside for a good hosing out. Sometimes I just give the coils a good spritzing, with the filter out, with windex with bleach. I'll use an old toothbrush to clean the coils, get down at the bottom where the stuff is clogged up.
Aug 18, 2008 | Goldstar M1003R Air Conditioner
Window unit spitting water
Check to make sure the drain holes are free from debris. The drain pan not draining causes the spitting and the fan is blowing out the water. Using a metal rod or hanger, gently clear all holes in the bottom of the unit. Prepare to get wet!
Jul 30, 2008 | Heating & Cooling
Washing Machines Logo
Top Washing Machines Experts
