Question about Canon PowerShot A530 Digital Camera
I can not get my pictures to transfer.
When I go to down loas nothing is happening.
  • Anonymous May 03, 2008
    i get canon power shot A530 driver 4 transfer to picture fron camera to pc
  • Shadee Jun 11, 2008
    It tells me to choose Cannon Camera Window for this action.
    Also tells me the destination has been changed. But I have not changed it.
Thank you sooo very much Mrs J Green. Thankfully I did not go with some of the 1st suggestions I saw previously to finding your suggestion. This fixed 2 problems I was having, 1 which was not mentioned above.
1st. my computer no longer gave me the option to upload pics when plugging in my camera, it just did nothing, but I also had to restart my computer after trying a few steps.
2nd. pictures that would show up on theplayback mode on the camera were not being read on uploaded to my computer from the card (also getting ready to reformat the sd-memory card to avoid further issues as such).
These were my mothers day pictures hence I soo much appreciate you that much more.....You Miss Lady are the Bomb!!!
Thanks
Sonrissa_27
Posted on May 11, 2009
    Novelist:
  • 130 Answers
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
Posted on May 30, 2008
I have an old Z730 Easyshare camera. I am trying to transfer the pictures to the computer. I plug it into the cable, turn it on and nothing happens. This is a new problem. I get nothing when befor
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Sep 12, 2014 | Kodak EasyShare Cameras
Won't transfer pictures
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Dec 02, 2013 | Nikon COOLPIX L810
When I plug cable from camera to USB computer connection, nothing happens!
Not enough information. The transferring of files requires a sequence of functions to happen before the pictures will transfer to the computer. You will need the camera software installed on the computer. The camera sequence for transfer and each camera is different, some just need you to turn the camera on after connecting the USB cable while others require you press the "Playback" button to transfer files. Depending on the camera software installed on a computer they "normally" download to a file folder then the pictures can be opened in the software programing.
Feb 08, 2011 | Cameras
My nikon coolpix s8000 will not charge and when i attempt to transfer pictures from the camera onto my computer (which has the nikon software already installed on it) nothing happens.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo management program, such as Picasa.
Organize edit and share your photos
Aug 28, 2010 | Nikon COOLPIX S8000 Digital Camera
Pictures will not transfer off the camera
Here's a silly suggestion for you... is the "lock" engaged on your memory card? It will be a small sliding lock portion on the SD card. If yes, unlock it and try again.
Apr 29, 2009 | Nikon COOLPIX P5000 Digital Camera
Transferring pictures from camera to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 07, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
I bought a photoframe-10FF2 series. I have a pc with lot of pictures-I want to transfer them--I have not been able to-please help
My philips Photo Frame does not work. It just get the "Please Wait" message when I start the photo frame. But nothing happens after that. Can someone help me please. I have reset the button, but nothing happens.
Thank you much...
May 16, 2008 | Philips PhotoFrame -10 Digital Picture...
Transfer pictures to computer
Apr 10, 2008 | Samsung Digimax S800 Digital Camera
Downloading pictures from phone to computer
When you connect the usb to the pc.....the phone should be asking if to do "transfer pictures".
select transfer pictures and a folder will be on you pc....select that
Apr 01, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Canon PowerShot A530 Digital Camera Logo
213 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
