Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Picture display I hooked up a high def reciever to try it out and the picture started fading in and out. I unhooked the reciever and reconnected the antenna and the picture keeps fading in and out on all stations.
  • Philips Master
  • 3,459 Answers
Is the picture getting smaller - then expands?
Posted on Jun 21, 2008
Picture problem on panasonic Vierra plasma tv
It looks like you are saying standard definition pictures do not cover the screen like HD pictures do. Standard def is formatted 4:3 and high def is 16:9. They are not the same so your high def screen is made to display the not as tall but wider high def picture. In order to fill the screen with the taller and not as wide 4:3 aspect ratio std def picture you must tell the TV to stretch the picture or otherwise fill the screen.The TV will have controls you can exercise for this purpose and you can set it up to always show std def in a particular manner. The alternative, if you want the standard Def picture to look true to form, is to view standard def in Letter Box form. It's appearance will then include black panels on the sides of the picture. So the problem is not with the TV but in accepting older format pictures playing on newer format displays (TVs.)
Mar 11, 2014 | Televison & Video
Picture problem on Panasonic Plasma tv
Mar 11, 2014 | Audio Players & Recorders
Our pitchure is not bright or clear as was in store
This actually common I worked in electronics for 13 years. Did they tell you that it has to be hooked up to an High Definition source. A digital cable or Sattelite reciever does not mean its HD also using Coaxle cableor composite(yellow,red,white) will not produce a good picture. You need HDMI or Component(RED,Blue,Green for video and red white for audio) to get a high def pic. Also not all station are broadcast in high def. One other thing is even if you have a High Def reciever you need to go into the menu of the reciever where it says display and and make sure its set for 1080i or maybe 1080p(most dont have this option yet) If you are using a normal DVD player and use the yellow red and white once again picture will be poor. Need to use Component or hdmi and again with component you need to set DVD to either 480p and if its upconvert to 1080p
Dec 14, 2010 | Vizio VO47L 47 in. LCD TV
No picture but have sound
Make sure your not trying to watch a high def channel, you will get sound but no picture if tuned to a high def channel on a non high def input or cable box. Try a vcr or dvd player connected to the unit to varify the picture tube has not gone out.
Sep 25, 2009 | Televison & Video
Recieving hy defintion picture
You need to do the following:
1: use HDMI cable to connect Cable box to TV
2: Call Cable company to activate HD service
3: Enjoy!
You can use component input, but the HDMI is best HD quality!
I hope this helps! please rate highly!
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
VIEWSONIC VPW425 42' PLASMA SOUND FADES ALL THE WAY OFF
I have a brand new Panasonic 42" tv, once in a while the sound fades out and then fades back in right away. I have it hooked up to a high def cable box with high def cable.
Jan 16, 2009 | ViewSonic VPW425 42 in. Plasma HDTV
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
Picture format
The HD reciever shouldn't be the problem.
If you recieve an image with a 4:3 aspect ratio, the image will be displayed at that ratio on your HDTV unless you specify otherwise. To do so go to your TV's Setup screen
setup
Choose picture formats
select smooth wide as your default
***Some digital (ATSC format) stations may transmit 4:3 images in a way that will not allow expansion. You will be unable to adjust the picture format.
Hope this helps!!!
J
Nov 17, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Picture problems
The pixelation is probably caused by MPEG2 compression on the DVD and Virgin media video streams, the blur is probably caused becasue you are displaying a standard definition signal on a high definition TV.
However if a high-def source still has these problems then you may have a faulty TV, your best bet is too hook up a high-def source such as a HD/Blu-ray player or PS3/360 games console.
Should a high-def source look ok, then you may have some look changing the display settings on the TV to try and improve picture sharpness and color balance.
Thanks.
Nov 08, 2007 | Televison & Video
Tperk
You probably do not have a high def signal.  If you do have a high def signal you need to use either component input or HDMI input to get high def.  I f you are using RF input you picture would improve marginally if you swithced to a video input.
Oct 23, 2007 | Panasonic PT-61LCX66 Television
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
