Question about GPS
I drive tractor trailers for a living this unit i bought keeps leading me the wrong way is there a way to enter the rout that i want to take using my lap top and the cord that came with it it is a garmin nuvi 350 and it dose have a truck setting and is there a 1 800 number that i can call for help
  • 504 Answers
What do you mean by, "leading you the wrong way"? No, there is no way to transfer a route from your PC to the Nuvi 350. I believe that unit does have a Commercial Vehicle setting. This should take you only on routes you can travel with such a vehicle. You can find contact information for Garmin at
Posted on May 02, 2008
How do i change the battery in L170 bobcat?
these compact units are tough to work on , the battery is located under the seat , but you cant get it out thru the service port there , unfortunly you need to raise the operators cab up , youre gonna need a hoist or crane if done in field 4 that there are are two remote jump posts located just inside rear access door that allows one to jump it to start and drive to service bay or trailer , as with any computer/electricial work allways OBSERVE poliarty of connections , cat tends to use black wires for both sides of battery , and if you get it wrong you just bought a new ECM (expensive!!!)
Dec 15, 2014 | Garden
Riding lawn mower
Some have belt guides. Often they are just metal rods that keep the belt somewhat tight to the pulley. Check these first as you should be able to visually see that they are positioned correctly. Other possible problems would be the wrong belt, a bad (bent) pulley or belt idler, or an incorrectly routed belt.
Aug 24, 2012 | Husqvarna Garden
Jusrt bought a mobil home with an Interherm unit. I live in Louisiana. When the air was hooked up is didn't cool very well. The fan motor outside had to be replaced. I was told it was the wrong...
There are a few things you can try.Close the vents half way in rooms your not using often too force more air to where you want it.
Inside coil and filter may be clogged or dirty.Change filter and clean coil with a degreaser spray,simple green works well mixed with water.
Thermostat location? is it in a common area like the living room.If not it should be there.
May 10, 2011 | Intertherm P3RA-024K Air Conditioner
Pig tail on chevy truck works on one trailer. When I connect to other trailer lights work but when you apply brake the tail lights go out on trailer. Blowing my mind. What is wrong? Do I need to rewire...
go on line and do a search for trailer wire diagrams and you will see and know what colors are used. they are black brown yellow and green and each one controls a different task.
Oct 16, 2010 | Dixie Winn Tractor Trailer Truck (The...
The belt dry rotted and flew off without me being able to remove it myself, now I need to know how to install the new drive belt.
To install the drive belt you will have to remove the drive belt first.
Follow the procedure: ---
Park the tractor on a level surface. Set the parking brake and remove the key from the ignition. Study the belt replacement guide decal located underneath the left foot board for proper belt routing instructions.
Remove the mowing deck by first moving the attachment clutch lever to the disengaged position (toward you). Move the attachment lift lever all the way forward to lower the mower housing to its down position.
Crawl beneath the tractor and roll the drive belt off engine pulley (it hangs directly beneath the engine). Remove small retainer clip that holds the clutch spring to the pulley bolt located at the center of the mowing deck. Remove the large retainer springs (two of them), then slide the belt collar away from the mower housing and off the housing bracket.
Disconnect the anti-sway bar rods from the chassis brackets by removing the retaining cotter pins. Disconnect front links from the mower deck by removing retaining cotter pins. Disconnect the suspension arms from the rear mower deck brackets by removing the two cotter pins.
Move the attachment lift lever all the way to the forward position to raise the mower suspension arms to the full up position. Slide the mower deck out from beneath the tractor.
Crawl beneath the tractor and roll the drive belt off of the stationary idler pulley and the clutching idler pulley. They are both located immediately adjacent to the engine pulley. Be sure the belt is already away from the engine pulley, as well.
Push the drive belt slack toward the rear of tractor. Remove the drive belt from the Trans axle pulley by taking it over the trans axle pulley while compressing the movable belt keepers surrounding it. Remove the old belt from the tractor by pushing it clear of the center span keeper (located beneath the Trans axle pulley).
Install a new drive belt by following the reverse of the instructions for removal. Test the tractor and mower for normal operation.
 Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jul 19, 2010 | Garden
Blades do not seem to have enough rpm at full trottle it leaves grass standing, have replaced all belts,tension spring,deck bearings,deck pullys,mule drive and front pto. new blades. what have i missed....
Are your blades rotating the right direction? Check to make sure that the blades are leading with the cutting edge as they spin. I'm not trying to insult your intelligence or anything, but on occasion we all goof on something, and I've actually had a few people bring me mowers that acted exactly like this, and I found that the blades were upside down, or they had the belt routed incorrectly and they were spinning the wrong direction.
Mar 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a Hopkins Brake Control the pigtail colors are Red, White, Blue, Black. My 2008 Chevy 1500 pigtail colors are Red with a black strip, Light Blue with white strip, Dark Blue, Orange, White. How do i...
1. connect the red wire to the stop lamp switch lead on the brake control. Connect the other end of red wire to the stop lamp switch in the vehicle using the splice connector
2. connect the blue wire to the trailer brake lead on the brake control. Route the other end of the blue wire to the trailer connector at the back of the vehicle.
3. connect the white wire to the ground lead on the brake control. Route the other end of the white
wire to the vehicle’s battery. Use the ring connector to connect the white wire to the battery’s negative terminal.
4. connect the black wire to the power lead on the brake control. Route the other end of the black wire to the vehicle’s battery. Use the fuse assembly to connect the black wire to the battery’s positive terminal.
Oct 22, 2009 | Chevrolet Silverado 1500 Cars & Trucks
How do you route the motion belt
Go to... Then enter the model number that is under seat. Should start with 917. Then scroll down to Ground Drive and there's your diagram.
Jun 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Why does the deck belt keep breaking on Poulan 18.5 hp 42" drive lawn tractor
its possible the belt may not be on the correct pullies. check the diagram and make sure it is routed correctly.the guy i bought my used mower from had same problem. i corrected belt route and have not broke a belt in the two years i've had it
Apr 11, 2009 | Garden
Drive Belt routing for Scotts Riding mower
I have to replace the belt part number m124895 on a Scotts riding mower.I need the belt configuration,since i bought it used.
Please help
Sep 25, 2008 | Garden
GPS Logo
110 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
