Question about Audiovox VE1020 10.2 in. TV/DVD Combo
No video My kids were fighting over who should be using the tv and one was turning the unit on and the other was quickly turning it off using the main power button. They probably did this 15 times and when I finally got them to stop there was no picture, sound works, radio works but no video using tv or dvd. Any suggestion as to what they may have blown
  • Ronald Tisdale
    Ronald Tisdale May 11, 2010
    Did you try to disconnect the power to the unit and let sit for a few hours?
  • 78 Answers
It's possible while they were fussing that the yellow video cable got jerked or pulled. try a new video rca cable.
Posted on May 02, 2008
I wanted to know hoe does YouTube effect kids negatively for a research project I am doing on social media.
OK kids as in young children ? there is a lot of content that is not suited for young kids and yet very little restrictions are in place some of these might be of a se.ual nature or blood and gore or mis- truths that can influence kids like alien stories ,ghost stories as well as videos showing others doing dangerous activities in vehicles or climbing thousands of feet above the ground with out safety equipment and just about any ******* activity gets posted on line like fights running from the police taking drugs or getting drunk .
Dec 05, 2017 | YouTube Computers & Internet
I have an Emerson LC320EM8A tv. I am able to turn the tv on either by the remote or at the unit. After about 15 min, the tv changes changes the channel to Video1. I can change the channel back to...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 10, 2017 | Emerson LC320EM8 32 in. LCD TV
My kids love doing pretend play but they always seem to end up fighting. Should I encourage them to do something else?
No! in a way it's a great thing that they are fighting as it's giving them the chance to learn to problem solve and compromise. Pretend play is like a snap shot of reality and your kids can learn some very effective skills that will help them in school and with friendships.
Feb 18, 2013 | Toys
Works fine untill the kids stomp on the floor then it flickers and picture turns oval or even goes blank
Sir the problem of your tv is just a cold solder or loosed connection, try to tap the side of your unit it will react. If you are handy in electronics you can repair it by your self using a soldering iron, soldering lead and desoldering pump. If you remove the back cover of your unit be to unplug your tv to main ac outlet. then pull out the main board be careful when removing the main board some connectors may accidentally remove try to put some marking to the connectors. It is much better if you have a magnifying glass to easily identify the loosed or cold solder. When resoldering be sure not to connect separated pin if accidentally solder or joined together it may cause much problem to the unit. Or you can contact a service technician to do it for you and save you from stress good day and best regards.
Sep 12, 2011 | Hitachi 53UDX10B 53" Rear Projection...
How can i watch an 18+youtube video without signing in or signing up?
Here is a simple hack for seeing those videos,
Just replace "watch" in the YouTube URL with "watch_popup" and the 18+ video will play on your screen without restrictions.
Example:
I am trying to see Gangster loses fight to next karate kid (real fight) video,
The URL is,
http://www.youtube.com/watch?v=O07u7KdRVo0
Now just replace "watch" in URL with "watch_popup"
http://www.youtube.com/watch_popup?v=O07u7KdRVo0
May 19, 2011 | Computers & Internet
I have a panasonic dmr-es20d dvd recorder. It has lost all of it's channels today, as expected but when I re-tune it it is not finding any. I have used an aerial socket that was used to successfully...
This worked for me... In the "Others" section of the Setup options, set Quick Start to Off. Then select and confirm the Shipping Condition option. Power the unit down using the unit's on/off button then switch the unit off at the mains. After a few seconds, switch it back on at the mains then turn it on via the on/off button. On power-up, it should (eventually) start scanning, but this time it should find the channels. I usually only need to turn Quick Start off to force a clock update when the clocks go back/forward, but it would appear that with Quick Start enabled, the unit attempts to used cached info about the channel multiplexes, which was obviously invalidated by today's mux re-organisation. Hope it works for you too.
Dec 02, 2009 | Panasonic Televison & Video
After a few weeks of buying my tv hitachi 42" lcd l42x02pxw istarted to have problems wih it. i use the remote to turn it on and off. the green light turns on however theres no picture. the tv screen is a...
If u buy this new,u got a lemon,This prob.is a
burn in use equipment,shouldn't cause this prob.for at lest 2 years.This is a comon prob. with a video Wharping heat exspand and contrast circuit board.
Aug 16, 2009 | LG 42LC2D 42 in. LCD HDTV
Orion STV 2763 27in TV
I am assuming that your TV has Video IN source selection.
You need to use the Video/Audio OUTput of the VCR/CD and connect them to the Video/Audio INput of the TV. To do this you would have to use a 3-wire shielded cable with male RCA connectors color yellow, red & white.
c296912.jpg RCA male connectors, yellow is usually video, red/white is audio left/right.
599898c.jpg as shown OUT of VCR/CD to IN of TV.
Pnce done, play the VCR/CD with a good known CD or tape and set TV to Video mode.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 31, 2008 | Orion STV2763 27" TV
Television
scanning the channels would not have done damage, the tv probably just sensed the unplugging of the power as a ''spike'' in the power line. Just let it sit unplugged for a while and then plug it back in, should turn back on again. also, if you are on cable or such, the scanning of the channels should actually be done, in ordr to see all available channels when the vcr is not in use, or if not, just set it to channel 3 or 4 to see it through the cable box. ps.. In the future, don't buy tv/vcr / dvd comos, the main reason why most peole buy those things is so the kids will leave the bigger tv set alone, problem with that is- kids will be kids, and sooner than later they will stick something the player's slot and screw the unit up- that leaves the tv by itself, which they will not want to see if the player is not working. so you are out of both and the kids are back taking the bigger tv away from you. best thing is always to buy separate units (vcr/dvd player combo's or separate units are usually cheaper to buy separately along with a dedicated tv than one of those all in one units. something goes wrong, just fix or buy a replacement for the system. and you get to keep your own tv.
Jun 12, 2007 | Sharp 35VX-H2000 35 in. TV/VCR Combo
Audiovox VE1020 10.2 in. TV/DVD Combo Logo
91 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
