Question about Kenmore 62602 Electric Dryer
Dryer shuts off
My dryer will run for about 10 mins. and shut off. it will not restart until it cools down.
I have cleaned the vents and changed the temperture switch.
it still shuts off.
help
  • wapiti13 May 07, 2008
    My dryer shuts off and when it cools down it will run again. I select no heat and the dryer run fine. Exaust and vent are clean and clear. The heater works but seems to be overheating. The motor works fine.
  • Anonymous Mar 16, 2014
    Dryer shuts off and won't restart until cools down
    Genius:
  • 1,028 Answers
Motor overheating ..doesit "groan" when start button pressed ? If so bad motor ..possible excess lint due to poor exhaust system caused lint build up around motor causing overheating and motor damage .new motor only fix
Posted on May 02, 2008
Electric dryer, runs for about 20 min then shuts down, can restart after a period of time, then runs about 20 min and shuts down
you have a bad motor,most likely you don't clean out the dryer,this is the number 1 killer of dryers.the vent line,the duct that the lint filter slides into and the cabinet where the motor is needs to be cleaned out if it's gas once a year,electric once every two years.all a dryer does is move air,when lint starts to build up the dryer starts to run hotter then normal from the lint build up and the dryer can't move the air as easy as when everything is cleaned out and then parts start to brake like the thermal fuse will pop from running to hot or the motor starts to over heat like yours and shuts down.when the motor gets hot the oil that's inside it leaks out,you'll see it stuck to the side wall and on the rear end of the drum with lint stuck to it.there's an overload in the motor that pops when the motor gets hot and after a while when it cools down the overload resets,that's why you can start it again after a while so basicly you have to replace the motor and clean out the dryer,if the vent line is a long run,remove it from the back of the dryer and with a leaf blower blow it out,you'll see all kinds of stuff blow out through the outside duct and clean out the duct that the lint filter goes into and the cabinet where the motor is or replace the dryer.
Apr 08, 2011 | Kenmore 62602 Electric Dryer
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
Roper dryer runs for about 5-10 min. then shuts off. After 10-15 min I can restart, but same thing happens. What up?
disconnect vent tube and run dryer, if it finishes the cycle then there is a restriction in the vent tube
Dec 26, 2010 | Whirlpool Dryers
My sears dryer will shot off when iy gets hot,going through its cycle. If i let it cool down for about 10 mins. I can restart and continue for another 20 mins before it shuts down again
Take the exhaust vent off the rear and try it.
If it runs OK,repair the vent blockage/restriction.
If it does not run OK,replace the motor.
Sep 27, 2010 | Dryers
My maytag dryer run for 10 min. and then stop. wont turn on untill cool down
Hello- The dryer may be shutting down because it senses low air flow or too much heat build-up. I would check the venting behind the dryer and make sure the flexible duct is not crimped or crushed, if it is remove it and replace (you can get this at most hardware stores). If that looks ok turn the dryer on and go outside to where the vent exits the house, the air flow should be strong. If you feel little air flow you may need to have a duct cleaning service out to get the lint build-up out, especially if the duct runs through the wall a long distance and makes many turns. You can also test if this is the issue by removing the flexible vent from the back of the dryer and running it; be aware you will get some lint in the room. If it is still shutting down you should have someone out to diagnose it, there may be a thermostat issue. Hope this helps, best regards.
I have a kennmore electric dryer all of a sudden it will only run about 10 minutes and shuts off when you try to restart it won't come back on you have to wait for a little while then it works but only for...
Sounds like it is getting too hot and the hi-temp safety switch opens up until it cools down again. Try vacuuming all of the vent pipes and hose. Remove the lint screen and wash it in hot water and detergent to clean it of fabric softener deposits. Hope this helps!
Feb 09, 2010 | Kenmore 63942 Dryer
GE Dryer model DDE5700GCLAD
Your dryer is exhibiting symptoms of a restricted/plugged exhaust vent. Remove the vent tube from the rear of the dryer and inspect it for restrictions all the way to the outside vent hood,(including the vent hood), i.e., lint build up/water retention, pinched-off, too long, animal nest, etc. Also make sure your lint filter is being cleaned after each load.
A blower malfunction could also cause your symptom. Do not overload the dryer as this also can restrict air flow.
Most dryers can only be vented 10 to15 ft. and should be cleaned twice a year.
Always utilize the shortest distance/shortest vent concept.
Jul 06, 2009 | GE DVLR223 Dryers
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
Dryer shuts off and won't restart until it cools off
more likely a bad motor ..excessive lint build up in dryer will reduce air flow through motor causing it to overheat problem is by the time the lint problem is found and corrected motor is already gone
Nov 20, 2008 | Crosley CDE6000 Electric Dryer
Kenmore 62602 Electric Dryer Logo
285 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
