Question about Mitsubishi WS-55511 55" Rear Projection Television
Will not turn on with remote or power button
It all started when it shut down and it would not power up again. I had a repairmen fix it, but it broke after he left. It will not turn on or off. I saw that a lot of people are having basically the same problems.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Is the front stand by blinking all the time if so u may have a bad DM module , 4 capacitor may be bad , also it may be the convergence ic with 2 pico fuse open 5amp
Posted on May 02, 2008
Sharp tv shut down after about 2 seconds
Could be power supply trouble. It tries to start but can't and shuts down.
Dec 06, 2013 | Televison & Video
Old bell expressvu remote and i cant syncronize it with tv. Remote works fine with receiver but i dont know how to rpograme it to shut off tv.
Hello!! There are a few ways to get this working to shut off the TV. I put some instructions at the bottom here. These are instructions for a power scan, which scans the TV for the correct code.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
Mar 01, 2011 | DISH Network IR Remote Control
WINDOW XP WOM'T SHUT DOWN
Hold the power button in for a few seconds it will shut down. Then unplug system and push the power button down with it unplugged then replug it in and power up again. Then do a proper shut down again to see if the problem fixed. I hope this assisted you. John
Feb 07, 2011 | Microsoft Windows XP Professional
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Hi...every time I turn off my RV-B90 I have to unplug it and plug it back in before I can turn it back on. Any fix for this?
This was happening on mine and here is how i fixed it.
I would hear clicking from the cassette area when i first turned it on, and the door would be jammed and i had to brute force it open. The kaboom would not shut down by using the power button or remote. Nothing!
I found the tape mechanism was getting jammed out of place because of all the gunk so I cleaned the inside with isopropyl alcohol and a q-tip then moved the mechanisms back and forth with my finger on the bottom where the tape goes over the sensor.
I powered it up with no clicking and was able to shut it off with the power button and remote again. My power issues had to do with the tape player whodathunkit.
Apr 19, 2010 | JVC RV-B90 Boombox
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
It will not turn on.
i have the same problem with the ws-65613 ,what do i tell the repairmen or how do i fix it my self.
Nov 09, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Samsung hcm4216w won't turn on light blinks then shuts down and tries to restart again
Your problem is TV is not getting enough power so you better buy a stabilizer and make the power to go thro the stabilizer to TV then it will get sufficient power supply everything will be smooth afterwards even the voltage problem.
Oct 17, 2008 | Samsung HCM4215W 42" Rear Projection...
Programming my remote to control the sound on my TV
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Jul 24, 2008 | DISH Network IR Remote Control
Echostar IR remote (Dish)
to set remote to tv
3)press pound sign
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
Mitsubishi WS-55511 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
