posted by docboy32 on May 02, 2008
How do you install this battery?
Comment by docboy32, posted on May 09, 2008
Thanks Jann! I must have typoed though,It's an Armada M 300, not 700... I DO appreciate your trying to help though!!
Doc
Doc
Best Solution
docboy, the battery on the M700 is locked in. Unlock it and pull UP on it. To put it back in you have to seat the end nearest the side of your laptop then push down gently on the end toward the middle. It will lock in and there ya go!! Hope this helps!
Jann
Jann
Comment by JannEd, posted on May 09, 2008
Doc: Okay. I have a CD with most all the manuals for Compaq. I just looked at the M300 and this is what it says about the battery pack:
1. Shut down the computer.
2. Turn the computer upside down.
3. Tilt the battery pack so it lies flat.
4. Slide in the two battery latches toward each other
5. Rotate the battery pack 90 degrees toward the computer , and lift up the battery pack from the computer .
If you would like, I could email you this .pdf file about the M300. It is 1839K and will take a bit to get it off my system (I only have dialup where I live.) Or, I will be at my daughter's tomorrow and she has DSL. Let me know. If you are planning on keeping the M300 you may want this!
Jann
Jann
Rating Locked! (?) docboy32 has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Compaq Armada M700 PC Notebook
Email this problem
Email this problem
Can you Help with these PC Laptops problems?
compaq armada m700 wont boot up
everytime i try to boot up my... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
