HP X4270 5 YEARS OLD. CONTROL PANEL READS HAXMNTE KHONKY B --NOT FAX,COPY,SCAN CONTROL PANEL DOES NOT RESPONSE TO BUTTONS. i UNINSTALLED AND THE SAME PROBLEM OCCURS WHEN I REINSTALLED WITH THE CD. NEW HARD DRIVE TO MY COMPUTER. DO I NEED ANOTHER DRIVER? THE REPAIR SHOP TO MY TOWER TELLS ME I JUST NEED A NEW PRINTER FAX COPY SCAN. ????THE FAX COMES UP WITH SINGAPORE, I CANNOT GET THE BUTTONS TO REGISTER OPTIONS CLEAR SELECT NO RESPONSE.
  • Anonymous Jan 08, 2009
    I have the HP C3180 All in One Printer. I turn on the unit and the check paper and check ink cartridge light continues to flash. I also cannot change any of the settings on the unit. What could the problem be ? Thank you
    Problem Solver:
  • 11 Answers
Step 1 Remove the power suppply from the back of the printer...
Step 2 press and hold the stop/clear button (the button with the red X)..
Step 3 Insrt the power supply into the back of the printer...keep holdin the button...
Step 4 The printer would display the language as english
Step 5 Select the desired settings
Vola ...ur printer should be back to normal...
Else contact on 1-800-332-4120
Posted on May 02, 2008
Hp 4355 reports no scan option when running under windows 7 It will copy to the printer
There is a workaround. As you no doubt know, windows 7 doesn't install HP solution center. So, to get a scan from your printer, or to send a fax etc,. you need to go to start > All probrams > Windows Fax and Scan.
From this program you gain all the functionality of your printer/fax/scanner, however the scan buttons do not work on the printer.
Nov 16, 2010 | HP Officejet 4355 All-In-One InkJet...
Upgraded to 7 now the fax wount fax. will scan and print
You still should be able to fax using the buttons on the control panel, but you're looking for a way to fax from the software?
This page explains what functionality is available on your product in Windows 7. The only driver available is the HP drivers included in Windows 7. Faxing is not mentioned.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01796736&cc=us&lc=en&dlc=en&product=1138342
Jun 04, 2010 | HP Officejet 4315 All-in-One Printer
HP copy function 'device not responding or is disconnected'
Did it work at all once you reloaded the software? Is the computer recognizing it in devices and printers? If it is present, right click on the printer, go down to properties and troubleshoot.... Let me know
May 11, 2017 | HP Officejet 5610 All-In-One InkJet...
I have hewlet packard all in one j4680 I can copy,print & fax. I want to know how to scan and put on the computer
You first need to have the HP software that came with the printer installed, and the most up to date drivers will also help make sure there aren't any compatibility issues.
Once you have that set up, on the control panel on the printer itself press the arrow buttons until you have Scan selected. Press OK. Press the RIGHT arrow to choose what you'd like to do with the scan when it's finished and press OK. Then press the START button.
You can also start a scan from within the program provided by HP with the printer, and many graphics editing programs and word processing programs (such as Word) have a Scan button. Sometimes referred to as an Inport from TWAIN Device or Scan from TWAIN Device. Simply clicking on one of those buttons usually starts the needed program to control the scan from on the computer, instead of using the buttons on the printer itself. (NOTE: The TWAIN device options are sometimes inside the Edit menu of some programs, so you may need to look for it a little.)
Sep 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Faxing Hp Photosmart C8160 Solution Center Doesn't Work
This might be one of the communication error issues,
if your printer is connectd to your computer tower using the USB cable make sure that the cable is not too long and also it would be better if you are using the cable that came with the printer
also check if the printer is not connected to a surge protector,it should be onnected directly to a direct power outlet.
check if you do not have multiple icons of the printer in the control panel under printer nad faxes
check if you have the right tab chosen for the printer in the solution center.
try a semi full reset which is # and 3
AS you said that a paid hp support couldn't resolve it
i offer you a free technical support.
i have troubleshot HP all in Ones for 2 years and would like to help you with this...
Jun 14, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hardware problem I think. Mine does not scan copy or fax nothin
I bought a new printer as I could not get help from HP support. I bought the HP 6310 3 years ago and it has never worked, except to print. No scan, no fax, no copy. I even paid for an additional year of warranty. The HP support people do not have a clue and are unable to come to the conclusion it is hardware related. When I realized they did not know what they were doing I pointed out that if it was software that was loaded on either of my computers, one Vista and one XP Pro, why did it not work and why would I be unable to make a copy by just using the copy button? The only comment I got was "could be" but that the only database the HP support people have access to is for software issues and he would not be able to help me.
It is my firm belief that the scan beds on these must be junk or the printer control panel and buttons do not function. I have read numerous reports of problems on many web sites, all scan related, can't copy or fax. I must have spent a total of 6 hours in several support calls to no avail. The will never suggest it could be hardware related. They even made me have a new disk sent to me $$ and of course nothing improved. But they made me a really GOOD DEAL on a new printer with a year of support included. He even had the nerve to try to sell me another extended warranty. I asked him why I would do that when I had absolutely no faith that they would do a better job in the future. If you have one that will not scan documents no matter what you do and it is out of warranty, you had better buy yourself a new one and get over it.
Good luck
Jun 05, 2009 | HP Officejet 6310 All-In-One InkJet...
Fax, Copy, Scan Buttons do not change
Sounds like switch inside operations panel has broken, there is no reset that will fix it, will need new operations panel.
the reset code on this machine is menu # 2 8 6 4 then maintence shows enter 99, the first bit must be done super quick.
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
59 people viewed this question
k24674
