I can't get the internet sharing to work. i had installed and configure the wireless router, Linksys WRTG45 connected to a desktop pc running win7. internet sharing is enabled on the modem. now we're using ad hoc connection to share this internet connection.
  • Computers & ... Master
  • 2,276 Answers
If you are using the wireless router then you will not use the Ad-hoc mode.
You aloso don't need to share the internet on the modem.
make sure that if you conecnt the computer directly to the modem, it goes on line.
If it is on line then you can connect the modem to the router and computer to the router.
open the setup page and change the settings of the router.
once ytou setup the router then you should be able to go on line on all the computer.
You just need to connect to the network on other computers.
Click Here for more information about the routers and network
Posted on Aug 18, 2010
SOURCE:
IP configuration address not shown. To summarise: We tried some time ago getting David's XP notebook and his Win7 desktop to share the Internet connection that his desktop has via an ADSL modem and...
Setup a new network under Control Panel > Network and Sharing Center > Setup a New connection > Setup a new Network. You need to make the Desktop as an Access point network. This will allow the Netbook to use the Desktop as a "router" and connect threw it to the internet. This is most likely the most time consuming way of doing it. The best bet would to pick up a cheap netgear or linksys router for better stability and ease of access.
Apr 13, 2011 | Trendnet NSPEED WIRELESS N PCI ADAPTER...
How to configure linksys wireless-g 2.4ghz broadband router i am using windowes xp,i have two LAN card in my pc.through internet sharing i connect linksys wirless router.wifi is working fine .i am able to...
try to factory reset your linksays and then connect your device.
after connection of your device re configure your linksys again with 192.168.1.1 IP address
Mar 16, 2010 | Computers & Internet
Setting linksys WRT54GX Ver2 with D-Link DSL-2450T ADSL2+router
Your router needs to be configured. Call Linksys Technical Support. If they cannot help you try this http://technicalsupport.blog.friendster.com
Feb 15, 2009 | Linksys Wireless-G WRT54GX Router...
ROUTER INSTALLATION AND CONFIGURATION
connect existing modem to the router
reset router (located at the back)
connect computer to one of the 4 ports of the router
run internet connection wizard & choose "computer is connected to a gateway / internet connection is always ON"
for wireless:
connect a computer to the router hard-wired
for your router, open a browser and access 192.168.1.1
leave it blank for the username and admin for the password field
click wireless tab, change the Wireless Network Name (SSID):
click save settings
next click Security Mode: and choose WPA2 Personal
make a password in the WPA Shared Key: field
click save settings
on the computer, go to view available wireless network & click the wireless network name you made, connect, enter password when prompted.
good to go
Jan 24, 2009 | Linksys Wireless-G Broadband Router
Help with my wireless router
you have the internet on desktop pc and you want to connect your laptop right?
open control panel select network set up wizzard and follow instructions for shared network.
if you connect dsl to notebook you need to have installed modem device drivers and configured device and done basically everything you had to do on pc,by disconnecting dsl from pc obviosly youre gonna lose the internet.
get your self a wireless router if not already have one , that way you set up pc wired and link laptop via wireless
Jan 09, 2009 | Computers & Internet
Setup linksys wrt54g2 broadband router with prolink h9200 modem
You probably will need to make some configuration changes in the Linksys router, or in your computer, or both. Your are correct that you connect the Linksys WAN connection to the LAN connection of the modem. If your connection type is PPPOE, you will need to set that up in the Linksys with the username and password provided by your ISP, so the modem will allow you to login and connect to the internet. If that is how you were connecting to the modem with your computer, you will need to configure a new LAN connection in the computer in order to connect to the Linksys. You can then configure the Linksys through your web browser to connect to the modem.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 27, 2008 | Linksys Wireless-G WRT54G Router
What are the step for setting up you computers to a network using a Linksys router. I have a 2 PC's and a laptop that I would linke to net work together. My first computer is connect to the Wireless-B...
Hi Ed, if your using windows you can open network connections & run network setup wizard. Follow the instruction for a home network for the wireless PC's & notebooks. Once the network is setup for all PC's than you can install the printer cd software in the PC's that you want to access the printer. Each PC & notebook will have access to the printer through the network.
The PC that that is connected to the printer needs to be shared.
Open printers and Faxes. Right click once on the printer & left click sharing. Agai follow the instructions.
Lastly,I strongly suggest you setup security for your wireless. If you do not anyone close can tap into your network connection. Follow linksys instruction to setup security. If you run into a problem you can call linksys for free advise from a pro. Their number is listed in the manual.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1175238819816&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1981627773H10
Good Luck! Take your time.
Have more questions, feel free to ask.
Mike
Apr 04, 2008 | Computers & Internet
Linksys Wireless-G (WRT54GS (EU/LA/UK))
I have had that issue quite often and found that when you are using a router with DSL, the DSL modem and Router IP has a conflict because they are the same number. I suggest looking into a D-Link wireless router for use with DSL.
Mar 17, 2008 | Linksys Wireless-G WRT54GS Router...
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
71 people viewed this question
Alun Cox
