Question about Microsoft Xbox 360 Console
Wont turn on
Checked all cords. plugged into main electrical outlet. still nothing.. a disc is also in it... not even a year old yet.
  • shaywayne Apr 09, 2009
    My console wont power on i dont even have the RROD. Power supply light is yellow until l plug into the console then it turns red
  • 156 Answers
Sounds like a power supply failure... before it stopped working was there a tiny "pop"... or a power outage. If there isn't the red flashing circle of death... the power supply is shot needs to be replaced it is still under warranty.
Posted on May 02, 2008
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
GE Profile Spacemaker XL 1800
Yes the main fuse has blown for several different reasons. If you have no electrical know how, or experience using a multimeter you really should have a pro take a look at it. It could be anything from a bad capacitor, a bad High Voltage diode, a bad door switch or maybe even a bad magnetron or a control panel. Not really a job for a novice to attempt, as the main AC fuse will not blow for no reason. Good Luck
Sep 17, 2007 | GE JE1540 Microwave Oven
We just bought a Mini Plus B31 coffeemaker and the cord will not plug into a standard three prong outlet. Other appliance cords do plug into the same outlets.
if you have a four pin plug, check that it is not three phase for heavy electrical use. ask your electrical supplier if your house has three phase, if your house had electric storage heating there is a chance it had three phase to balance the electrical supply to the property this can be dangerous so check please (some old boilers were two or three phase years ago)
Jan 18, 2012 | Dryers
The electricity went off to my printer and it hasn't worked since. I have tried turning it on and off. I have tried resetting the ing cartriges . I have tried unplugging , waiting and replugging. Nothing...
Which brand/model of printer do you have? Check the warranty for the printer and contacting the manufacturer, if it is under warranty.
First though what type of power cord does the printer have? If there is a power module (brick), disconnect the cord from both the printer, the wall outlet and separate the cord from the module. Wait a minute and then plug the cord into the module and then into the wall outlet. If it has an LED, is that LED lit? (Check the printer itself or the module and find out what power should be getting to the printer. If you have a multi-meter, check if the cord is getting the correct power level.) Try another power cord if you have one that matches the connection and the voltage output (for a power module).
Some printers have a soldered-in fuse and it should be handled as a warranty repair when the printer is under a year old.
I hope this helps.
(I'm currently waiting for a return shipping label for a similar printer issue. HP gave a credit for a new printer instead of sending a refurbished unit. I didn't have a spare power cord but did have 30 V at the printer side of the power module's cord. This was at the specifications for the unit. This is the first HP printer I've ever had fail within a year. Previously the ink jet failed after 9 years of use.)
Apr 02, 2011 | Office Equipment & Supplies
Olevia 37" no picture
check the TV power cord first., try to plug any other appliances on the same surge protector or outlet, like electric fan, electric iron., see if's work., if it does, probably the power supply of your TV is in trouble.
May 09, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
GE Harmony Profile
Did you check the terminal block where the cord plugs up and ohm the wires in the main cord? If thats not the problem then you might have a bad computer and or inverter.
Jun 30, 2008 | GE Profile Harmony DPGT750EC Electric...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
