Question about Jenn-Air JGD8130 Gas Cooktop
Replacement Ignitor for JGD8130 Grill..
I have lost the ability to use the electric ignition on the grill side of the unit.
When cleaning it one time, I notice a small black metal ring fall off and hit the floor. Upon looking it over, it has two small fins, of which it looks like one broke off (it looks corrosion or rust contributed to this). However, I found where it went, and place it back where in the middle of the sealed burner component. It fit and I could get it to lite again. However, we hired a new household cleaning staff, and upon their cleaning -- it looks like the made the same mistake I did, but discarded the black ring. Now the only way I can get it to lite -- is with a grill lighter.
Can anyone help me identify this part -- if it can be purchased separately or if this is one of those items where the entire component has to be replaced. Seems like a simple part. Just need to know as the cleaners will purchase a replacement for me.
I have scanned both the installation guide and UG, and there were no breakdown of parts to give a better description or part number.
  • 1 more comment
  • jewettg May 02, 2008
    Never mind. Some more Google Searching turned up a site that had break-out images of all the replaceable parts for my Jenn-Air unit.
    You do not need to replace the entire sealed burner unit, just the igniter portion -- a $15 part. A little more than a black ring (also notice this is not supposed to be black -- but a silver ring.. I guess the grilling and heat tarnished it to black).
    http://www.appliancepartspros.com/partse...
    Cheers!
  • susansarah May 27, 2008
    I have also lost the ignition on the right side of my unit. It clicks, but it will not ignite. I have used the manual to troubleshoot-still no success. I do smell gas, so the gas is coming out, it is the ignition port.
  • dragonness Jul 08, 2008
    Same as above, our lower right burner igniter isn't working well. Sometimes it'll spark, other times, the gas comes out but no spark. We use a grill lighter on that burner, just to be on the safe side.
    Is this fixable without a service call?
aborcass
  • 2651 Answers
SOURCE: Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Posted on Feb 23, 2008
SOURCE: Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Posted on Jul 07, 2008
Eddie Rentas
  • 59 Answers
SOURCE: broken griddle control
Hello
It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • Posted on Jul 26, 2008
    odiebugs
    • 949 Answers
    SOURCE: broke glass on electric genn-air
    Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
    Look at the cost of a new stove, you should be able to get one for
    around 400.00. One of my customers had a glass top with 4 burners,
    they had the same thing happen, the cost to replace the top was
    1,200.00. So I would assume that you can get a new stove with 4
    burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
    they seem to be everywhere,like death and taxes.
    As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
    I looked at the model# you put down,and it does not have a grill,
    from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
    If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
    400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
    If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
    Posted on Mar 24, 2009
    • 222 Answers
    SOURCE: Electric ignitor does not work at all on Jenn-Air Gas cooktop
    need to replace the ignition coil.no adjusment the unit is power operated 1st check the plug,outlet or main swicth sometimes not properlly connected.
    Posted on Jun 23, 2009
    How to replace electric ignitor for outdoor grill?
    it may be that the electricity or the spark is connection to different point of the grill, the electricity will spark to the closest point of conductivity.
    if you check and each ignitor is sparking , strongly ( so no problem with spark modual), then there may be points in the wireing whichis exposed or more likely where the wireing and the ignitore connects,
    you can tape it with electrical tape, then it should see the spark to the burner. if it is sparking, and not to the burner, just means it is sparking to a different point, where the jump is shortest.
    Apr 18, 2013 | Cooktops
    Grill will not ignite-glow pug is bright red
    Just because it glows that does not mean it is not bad...
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
    Oven Problems Replacing the Igniter
    http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
    heatman101
    Feb 14, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
    After using the grill cartridge for the first time, and then replacing it with the double burner cartridge again, now the fan goes on every time we turn those burners on. This is a grill only feature. ...
    There has got to be an interlock that is actuated by inserting the grill into the cooktop. That interlock switch or sensor is probably stuck closed and still is sending the signal to the stove that the grill is being operated, not the burner cartridge. Pull the burners out, insert the grill back into the cooktop a few times feeling for interference or something not seating right. When you find the interlock or sensor, inspect it to see if it is hung up, clean it, adjust it, or tap it lightly. If the switch/sensor is operating properly, reinsert the burners, make sure the fan is turned off, and operate them, checking to see if the fan is now off. If not, there is either a faulty sensor or a fault in the signal line to the control board or in the board itself. But a hung up interlock is what I would be looking for first. Good luck.
    Dec 07, 2009 | Jenn-Air JGD8130 Gas Cooktop
    Burner sparks repeatedly
    there is a chaffing problem on this unit on the left side of control remove nobs remove the cover and inspect for chaffed wires or oone that has come out of the ignitor
    Aug 09, 2009 | Jenn-Air JGD8130 Gas Cooktop
    KitchenAid Stovetop with grill and griddle - KGCP484KSS0
    hi im gerbee, try to clean the sensor valve by using a scott brite, the sensor place in the side wen the flame is on like a gold metal, 2nd try to adjust the flame control by using a plat or + screw,u see it at the gas control knot on top the small screw.adjust to high flame is touch the sensor valve.sory for my english.tnx gerbee i hope i help u
    Nov 30, 2008 | KitchenAid Architect KGCP484KSS Gas...
    Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
    Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
    JENNAIR DOWNDRAFT COOKTOP
    bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
    DMA Jennair The fan motor is bad and needs to be replaced.
    I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
    Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Jenn-Air JGD8130 Gas Cooktop Logo
    185 people viewed this question
    Top Jenn-Air Cooktops Experts
    Dan Webster
    Dan Webster
    jason
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
