Question about Dryers
My Lg dryer is no longer getting hot - Dryers
  • 172 Answers
Not heating is really a common accurance.
The first thing to check is your voltage.
Make sure you dont have a kicked breaker
as this will cause the dryer to run but
not heat. Check the cord for burns or
broken wires, then check the terminal block.
next I would check the heating element. This
can be checked with any multitester. Simply
remove one of the wires from the heating
element and read accross the heater for
continuity. Then check to see if the heater
is reading continuity to ground. If the
heater is good then move on to the thermostats.
remove one wire from the thermostat and then
check for continuity. If you find one that is
not getting continuity then you have found the
problem. If you have not found the problem by
this point is is usually best to call for service.
Misdianosis can get expensive so dont just run
out and buy that $130.00 timer unless you know
its bad. Good luck and I really hope this helps.
Mike Anderson mca0824
Posted on May 02, 2008
Maytag dryer no longer getting hot
There are several components on a dryer that can cause this problem. The most common is the heating element. There are also thermal fuses, bad timer, or improper voltage that can cause this as well. All are very simple parts that you can test with an ohm meter Or volt meter.
Mar 07, 2015 | Maytag Dryers
Dryer not getting hot
There's a thermal switch on the elements or the elements themselves may have burned in two and need replacing. Unless you know something about electrical and controls, I'd get a pro to check it...
Mar 19, 2014 | LG Dryers
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
My Whirlpool GOld Ultimate Care II electric dryer is not drying well any longer. It is 5 years old and a load must be run 2-3 times to get it to dry. Please help.
it could be your heating element but if you use dryer sheets take your lint trap out and see how well water will run thru it it may need to be washed in hot soapy water hope this helps
Dec 13, 2009 | LG DLG2524 Gas Dryer
LG dryer will not get hot
ur heating element is broken..order a new one, out it in, and presto!
Oct 11, 2009 | Dryers
Lg dle7177 electric dryer
The cool light on the lg is on all the time. It is only actually cooling when it is flashing. You might have a blown thermostat. Call a tech and have him/her check it out.
Sgt48
May 18, 2008 | LG DLE7177 Dryer
LG dryer, keeps asking me to clean filter, I checked the door lint filters & the condencer?? any idea
hi my dryer no longer gets hot enough to dry my clothes without
having to run it for almost 2hrs for one load...this is a big problem..
can someone help me find a answer on model# DC-382WD. I search this model and it tells me it doesn't exist???
thank you,
Cid.
Apr 29, 2008 | Dryers
Dryers Logo
90 people viewed this question
Top Dryers Experts
