Question about Philips Magnavox 20MS233S 20" TV
27 in Magnavox Smart TV
I pruchased this TV 3 years ago . It worked great until a couple months ago. The picture is clear, the sound is great, it does hesitate to come on when I first turn it on; however, now, there is a black screen about 2 inches from top, it is as if the picture is falling down and it does not correct itself. This is a horzional bar that stays black. Is this a major thing or is it fixable. Thank you.
  • Aziz Chaudhry May 11, 2010
    Is there a black bar at the bottom also?
  • Philips Master
  • 5,138 Answers
Problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
Posted on Jun 25, 2008
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
Take of the back and there is buttons inside, try turning them.
Nov 25, 2013 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
I have a 42 in magnavox 43mf439b/f7 tv. It is about 2 years old. i have no picture but i have sound. if i change channels the sound changes. I did a little research and i believe that i have...
You were smart to test the image for burned out backlights! :)
Typically, on a screen this size, the backlight inverter is the first place to look.
I found the part number...
27-D026774 Funai TV Module, backlight inverter, PNF10092, I420H1-16A0, 42MF439BF7
You can by it here...
http://www.tristatemodule.com/p-13231-27-d026774-funai-tv-module-backlight-inverter-pnf10092-i420h1-16a0-42mf439bf7.aspx
Aug 23, 2011 | Magnavox 42MF439BF7 42 in. TV
Horizontal Line through middle of TV screen
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
NO SOUND/CLEAR PICTURE
Please do not do all caps. It makes it harder for us to understand your problem.
Check the speaker settings in the menu and in the case, BUT NOT UNTIL IT IS UNPLUGGED FOR ABOUT 10 MINUTES! TVs have caps that hold up to 30,000 volts and take a while to discharge.
Oct 05, 2008 | Philips Magnavox Learning Universal Remote
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Hilips Magnavox TV- Model # MS3250C321, Serial # 77488694
Anything can be repaired, question is how much it will cost you.
Sounds like a problem in the high tension side of tv, wether it is the transformer or leakage remains to be seen.Also because it is aggravated by damp weather.
May 12, 2008 | Philips Magnavox 27MS343S 27" TV
TV wont come/stay on
helene dear your tv need be checked for the inside there is problem in power supply need be fixed.and your will see it"for more help see expers near you.
Nov 02, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 20MS233S 20" TV Logo
269 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
