Samsung DLP 42 inch TV broke.
When you plug the set in it makes a loud roar and the lamp does come on.
  • EarlNancy May 06, 2008
    dismantled the color wheel unit found that the color wheel broke apart. Have ordered new unit . Thanks.
  • 8,617 Answers
Sounds like the light engine itself is defective as the color wheel would make a whinning noise
Posted on May 02, 2008
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
My 56 inch hi-def projection samsung tv turns off automatically
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Mar 06, 2009 | Samsung DLP HL-P5663W 56" TV
    DLP TV noise and picture
    This is not with the problem of lamp.
    Your light engines COLOR wheel is damaged.
    Replace Color Wheel.
    Good Luck
    Dont forget to Rate!!
    Dals123
    Nov 05, 2008 | Televison & Video
    TV TURNS OFF AFTER 20-30 MIN
    May 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
    Televison & Video Logo
    76 people viewed this question
    Top Televison & Video Experts
