Question about Pantech Duo Smartphone
Removing all messages doesnt seem to work
Ok i did the clear all messages like u said in another persons quesiton.. but it sits there with that 4 color circle and never gets off it. so i have to take the battery out and put it back in caus it freezes it.
HELP whats going onn
  • 3 Answers
Same problem with mine.
first step: change settings so it doesnt save the sent msg's
second step: devote a lot of time to manually deleting them one by one
Posted on May 07, 2008
    Problem Solver:
  • 11 Answers
When you delete all the txts at once it just takes a long time, your phone isnt actual frezeing, just leve it be for a while eventuly all the txts will delete
Posted on Sep 21, 2008
I HAVE A UNIDEN d1680 SERIES PHONE AND WHEN SOMEONE CALLS TO LEAVE A MESSAGE IT DOESNT LEAVE ONE. MY ANSWERING MACINE IS ON AND SO IS THE VOLUME. I TURNED CALL SCREEN ON. WAS I SUPPOSE TO
Try to reset the phone, remove all the handset batteries, disconnect power adapter and let it sit for 3-5 minutes and put back the system. This will remove all the phone memory and clear all the glitches.
Oct 14, 2011 | Uniden Lands Phones
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
When turning on my Picture Mate,it says ERROR: Paper is jammed in the printer, remove the jammed paper, then Press (OK). I have done this many times and still get that message. What do I do?
I own a PictureMate Epson personal photo lab. It has been sitting on my desk for over 1 year with the message Error:Paper is jammed in the printer. Remove the jammed paper, then press (OK). I have done this, many times, I have talked to a "solution Person" and unfortunately they have told me it can't be fixed. I am just warning anyone else, not to buy this product. I have printed less than 100 pictures and it now doesn't work anymore. Just DON'T BUY THIS EPSON PRODUCT
Dec 30, 2009 | Epson PictureMate (C11C556001) InkJet...
Trying to unhibernate my compaq C700
Did you try removing the battery and the power cord and letting it sit over-night?
Give that a try. If it works - Great. If not - post a comment to this quesiton and we will try the next thing.
Thanks for your question.
Dec 24, 2009 | Computers & Internet
My fridge in my fridge freezer keeps freezing everything in it.
If the fridge side is frozen you have a door seal issue.
If the freezer side is frozen you have a defrost component issue.
Your post was not clear as to which side is frozen.
Jun 16, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
How do I clear the er if message on the door? Everything seems to work fine.
I unplugged the refrigerator (flipped the breaker) and let the refrigerator sit opened for four hours. That apparently allowed the ice that was freezing the fan to melt. All is now well.
Apr 09, 2009 | LG LFX25960 Bottom Freezer French Door...
LG Phone has Car Kit Error. Didn't Get Wet. Can I Clear it
Dear customer,
                     To Remove “Car-kit” error there are few ways:               What worked for me as suggested by chemist  is using Calcium Chloride (CaCL2) as a drying agent since it pulls moisture out of the air, and according to Verizon, this car-kit error is caused by exposure to moisture. For the average person, you can find this in the form of “Prestone Driveway Heat Concentrated Ice Melter” (or other ice melter – check ingredients).
1) Pour about 1 cup or so of CaCL2 in a small Tupperware container.
2) Place a sheet of paper on top of the CaCL2 to protect the phone.
3) Place the phone on top of the paper so as not to allow phone to touch CaCL2 (this is important).
4) Place the lid tightly on the Tupperware container.
5) Allow to sit overnight.
In the morning, the “car-kit” error was gone! Yay! I could could hear my callers, they could hear me, and I could hear all my ringers.
                         Other suggestions that  might work for you are.
         Car Kit
 To remove errors from phone:
#1) press soft key for menu
#2) then press 0
#3) you'll have a service code prompt, type 000000
#4) then type 2 (it should be field tests)
#5) then type 4 (clear errors)
#6) choose yes for clear errors
#7) press clear once
# type 8 (FCC test)
#9) type one (pcs)
#10) type one again (set channel) (mine shows 426 I don't know if theres a different channel for each phone.)
#11) press clear 3 times and the phone will reset.
                       FOR RESTTING
Enter "Menu"
Select "Settings"
Select "Security"
Enter "Lock Code" - Will default to last 4 digits of phone number or "0000" unless changed.
Select "Reset Defaults"
Press "Ok"
Plz rate this solution.. thank you..
Apr 09, 2009 | LG VX8300 Cellular Phone
Pantech Duo Smartphone Logo
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
