Question about HP Photosmart C6180 All-In-One InkJet Printer
Print cartridges i keep getting a message that says my printer cartridge needs replaced and will let me print if i say i will print only with black. after that, it will not let me print...it says cartridge must be replaced. I have replaced the cartridges, but still get the message. HELP
  • SCARLETM May 31, 2008
    I REPLACED MAGENTA & YELLOW & IT STILL WON'T PRINT. IT KEEPS ALL PRINTING IN QUEUE
  • Anonymous Jun 18, 2008
    Novelist:
  • 79 Answers
reset the printer .
Steps>>
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note >
in case it does not work try the same steps but take out the cartridges from the unit and insert them when prompted.
Thanks.
Posted on May 28, 2008
I have replaced black ink but printer keeps telling me to replace black ink cartridge
If the it's a remanufactured cartridge (not genuine), the printer will not detect the ink in the cartridge.
If it's genuine, you might want to give Lexmark's technical support a call to have the cartridge replaced.
May 05, 2012 | Lexmark X4650 InkJet Printer
The printing speed slowed to a snail pace. I pressed Setup, 2, and then 6 to print a self-test report. I got a a "cartridge error" message. Then I removed both cartridges and cleaned them. Still...
This is caused by the failure of one of your cartridges. Remove the black cartridge and print a test page. Does the printer print at normal speed? Is so the black cartridge was the issue and should be replaced. If not then put the black cartridge back in and remove the color cartridge and print test page. If the printer now prints normal speed the color cartridge was at fault and needs to be replaced.
please vote for better sharing.. thank you and good luck
Nov 24, 2010 | HP Officejet 5610 All-In-One InkJet...
Replaced black print cartridge rejected.
Hi there remove the cartrideg & reset the printer first. After that off the printer. Now fix the cartridge in printer. Turn on again. If you face same problem then reset again with cartridge, give a test print from print preferrence. I hope your problem will solve then. Thanks & waiting for your feedback.
Mar 18, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Printer light keeps flashing and will not print
Use ONLY GENUINE HP ink cartidges. This will fix it.
Jan 04, 2010 | Dymo LabelWriter 310 Printer
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Aug 13, 2009 | Dell A940 All-In-One InkJet Printer
Print WITHOUT colour cartridge
If you right click the printer in the Printers section of the control panel and select printer preferences, there should be a tab called maintenance. In this tab, you should find a setting called Ink Cartridge Settings. Once you click on this setting, click black cartridge only. This should allow the printer to only use the black ink and therefore you won't need color.
If you have any other questions or this doesn't solve your issue, let me know.
Jan 10, 2009 | Canon MX300 Office All-In-One Printer
PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Sep 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Just replaced my black and color cartridges with new lexmark...
Hi tfonts,
This is normal behavior for proprietary print devices if you have not provided them with a new print cartridge and have instead filled them yourself.
Terry
May 08, 2008 | Lexmark X5470 All-In-One InkJet Printer
Error message Alignment
There is no doubt in my mind it Will be the cartridges you are using, alignment will continue to be requested if print out is missing bits do yourself a favour and use HP gen., not trying to plug HP just telling you the facts
Dec 06, 2007 | HP PSC 750 All-In-One InkJet Printer
Printing
Phisically unplug the printer and wait a minute. Plug it back in with the new cartridge installed while the printer is off.
Aug 26, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
55 people viewed this question
Ben Johnson
