Question about Yamaha R-V905 Receiver
Yamaha R-V905 constantly turns itself off
Recently my R-V905 has started turning off every few minutes. I'll turn it to Standby then turn it back on and it will stay on for a few more minutes, then off again. Sometimes it seems to happen when there is a loud volume spike.
  • billybantha May 03, 2008
    I don't think it's ventilation, since its been in the same case for 9 years.
    I've experimented and it definitely is volume-related. It now turns off when the volume goes over a quarter-way on the dial. Any
    Any ideas what could cause a volume outage?
    Scholar:
  • 79 Answers
Two things I think are happening. It is overheating and it has suffered some sort of damage to a component inside. Try to make sure there is ventilation on all sides. Can you remember a time where you did not have adequate ventilation for this device? If so maybe that is what caused the part inside to fail.
Hope this helps
Thanks for reading!
Posted on May 02, 2008
  • Aziz Chaudhry May 04, 2008
    Im guessing that it must be either a voltage regulator or maybe a capacitor? Im not sure.
    Sorry I could not help further.
What cable do you need to connect reciever to hdtv?
R-V905 doesn't appear to be HD compatible. It would need to have HDMI or component connections but the amp only has composite.You can only connect using the yellow video cable.
http://download.yamaha.com/api/asset/file/?language=en&site=usa.yamaha.com&asset_id=35276
Jan 21, 2013 | Yamaha R-V905 Receiver
Yamaha receiver shuts off
my Yamaha rxz1000 will turn off byitself
May 03, 2012 | Yamaha R-V905 Receiver
LOSS OF BASS IS THERE A FUSE IN THE RECEIVER FOR THIS
Jeff, The speaker it self may be fused. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Yamaha V905 Owner Manual
YAMAHA RX V595 V905 RX V595RDS Service Manual free download schematics...
Feb 27, 2011 | Yamaha R-V905 Receiver
Will not turn on.
It has an internal problem. Just received an RX-V2600 back from service for the same issue. It took a voltage drop then a spike. It takes out 5 caps and a few other parts. The repair will run roughly 250-275 depending on who does the service. Hope this helps
Aug 14, 2009 | Yamaha R-V905 Receiver
Goodmand 42'' TV turns itself off
Check to see it your TV has a timer and it was accidentally touched to activate. Good luck.
Jul 04, 2009 | Televison & Video
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Intermittent blank screen with r,g and b semi-circles at top of screen
the blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
Sep 09, 2008 | Sony KP-46V35 TV
Sony Grand Wega
The first place to start is to change the lamp.
May 18, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Digital TV Converter keeps shutting off
The DTA800 has a Power Saver feature that turns the unit off after 4 hours if it is idle (no volume or channel changes).
Press MENU button, press #5 (Setting/Configuration), press #3 (Power Saver) Select OFF to de-activate this feature (no Power Saver).
This is covered on page 11 of the DTA800 user manual.
Apr 25, 2008 | Televison & Video
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
Yamaha R-V905 Receiver Logo
217 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
