Question about Kodak Ektapro 9020 Slide Projector
Slide indexing problem
My ektapro indexes and allows each slide to be screened twice .is t it a setting problem or a slide mount thickness problem
    Scholar:
  • 33 Answers
I haven't seen one of those for quite a few years but my guess is that something in the slide changing mechanism is dirty and/or the lubricant has dried up somewhat. Best guess is the indexer lever, the one that pulls in toward the centre of the projector as the slide moves forward. See if you can clean / lube (with very light grease like "Super-lube") that mechanism.
It is possible though uncommon for the advance lever to get out of whack but I can't recall what's involved in adjusting that. I'd strongly suggest a professional take care of something like that- you could do more harm than good playing with it yourself, esp. without a service manual.
If you are in the US, google Fargo Enterprises Kodak... and if in Canada, Doug Banks Photo
Posted on Feb 20, 2009
We have new and old Kodak Ectapro 7020 & 7010 projectors. What could we sell them for?
Check with: www.vinevalleyimaging.com for current market pricing on Ektapro Projectors and Accessories. Good Luck!! Jim
Oct 21, 2011 | Kodak Ektapro 7020 Slide Projector
Vvv cvv
Contact me directly through Fixya with your Ektapro problem! Jim
Aug 12, 2011 | Kodak Ektapro 7020 Slide Projector
What manufacturers warranty came with a Kodak Ektapro 5020?
1 year from date of purchase (U.S. warranty only). But with the business discontinued at Kodak, they are no longer accepting warranty claims.
Good Luck!
How do I print index cards through my bizhub C203?
use bypass tray, you must use thick 3 or thick 4 and the size needs to be close to the size of index, the tray settings need to be set for thickness and size and color then the same has to be set in the driver in computer also, when you go to print hit properties and change the tray to bypass and thick 3 or thick 4 and then the same size you selected in the copier and it should work. if by chance it asks you load paper in bypass after you hit print then it didnt get setup correct. check to see if you got the driver saying the same as the copier tray. ask if you need help
Jul 28, 2011 | Konica Minolta Bizhub c203 Copier
I used my two Kodak s-av 2020 projectors with dissolve gear.after 2/3 years interval neither will change slides either way. Engaging the gearwheel by hand (normally driven by the solenoid) changes slides...
A tough one! Are these S-AV Projectors or Ektapro Projectors? There are no parts or factory-trained repair dealers for S-AV in the U.S. anymore. If they are Ektapro, then you can contact Langie AudioVisual on West Commercial Street in East Rochester, NY. I believe they still have a part-time tech who can diagnose Ektapro problems. I'm sorry the news isn't better....
Jul 03, 2010 | Office Equipment & Supplies
Deleting files
Im assuming you want to delete browsing history. You can go to Internet options in the control panel and delete browsing history there but to completely remove history files you need to delete the index.dat file.
This file, if you're using windows XP can be found in different places:
C:\Documents and Settings\<username>\Cookies\index.dat
C:\Documents and Settings\<username>\Local Settings\History\History.IE5\index.dat
C:\Documents and Settings\<username>\Local Settings\History\History.IE5\MSHistXXXXXXXXXXX\index.dat
C:\Documents and Settings\<username>\Local Settings\Temporary Internet Files\Content.IE5\index.dat
C:\Documents and Settings\<username>\UserData\index.dat
If you are using a different operating system, just search for index.dat and make note of the locations.
Once you've noted where the locations are you need to restart the computer and log in using safe mode. In safe mode pull up a cmd screen by going to start>run> then type cmd and hit enter.
In the cmd screen change directory by using the command cd C:\Documents and Settings\<username>\UserData for example and then del index.dat (to delete the index.dat file).
Restart and you're good to go.
Apr 06, 2010 | HP Pavilion dv6000z Notebook
Projector light does not shine. (Power is on, bulb
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
Dec 16, 2009 | Kodak Ektapro 9020 Slide Projector
Konica 2223 J72 alarm
ST216, J72.
Solution:
PROBABLE CAUSES:
1. Paper is caught on the flapper assembly (p/n 12TK-4510). The indexer is not adjusted high enough to have the flapper correctly positioned. This symptom usually occurs after the last copy enters the top bin. To properly adjust the indexer position, perform the following:
a. Power copier OFF.
b. Remove the front and rear covers.
c. On the sorter CB, set dipswitches SW1-1, SW1-2 and SW1-3 to the ON position.
d. Ensure both sorter interlocks are closed (PS208 and MS201).
e. On the sorter CB, press and hold PSW1 while powering ON the main body (code 70-00 will occur; this is normal).
f. Release PSW1, then press and release it one time. The indexer will lower to the adjustment position (approximately at the 4th bin).
g. Open the conveyance section.
h. Insert the indexer positioning shaft adjustment tool (p/n 7050K0020) into the access hole on the rear side frame of the sorter. The hole is located to the right of the conveyance door interlock switch (MS201). The shaft should be positioned under the indexer and into another hole in the front side frame.
Note: The indexer positioning tool is the same tool used for optics alignment on the 7050.
i. Rotate the indexer motor encoder plate to lower the indexer until it contacts the adjustment shaft.
j. Loosen the fixed screw located on the front side of the indexer.
k. Slide the front of the indexer up or down until it is positioned parallel with the adjustment shaft. Retighten the indexer fixing screw.
l. Loosen the screw that secures the PS203 4-slot encoder plate and adjust the 4-slot encoder plate until LED 1 is lit. Retighten the encoder plate.
Note: Either or both interlock sensor/switch (PS208/MS201) must be opened during this adjustment.
m. Remove the indexer positioning shaft and reset all 3 SW1 switches to the OFF position.
n. Power copier OFF/ON to return to the normal mode.
2. The sorter top front frame is slightly bent and not parallel with the rear top frame. This, in turn, allows the top cover to be out of position and bind the flapper gate (p/n 12TK-4510). This gate should normally open when the indexer lowers to bin 2, allowing the paper to enter the bins.
Reform the sorter top frame so the top cover, when mounted, does not bind the movement of the flapper gate.
3. Mylar guides are installed on the exit unit of the main body.
Remove the mylar exit guides when a sorter is installed. The guides help eliminate static when paper exits into the catch tray. When a sorter is installed, the guides can cause exit misfeeding.
4. The flag for the sorter entrance sensor (PS201) is stuck on the guide plate below the sensor. This happens when the top of the sorter is lifted as it is moved away from the copier.
Lift the top of the sorter and place the flag back into its proper position. Instruct the operators not to lift the top of the sorter when it is moved.
HOPE THAT HELP
THIS IS ONLY FOR ST216 MODEL SORTER
Oct 15, 2008 | Office Equipment & Supplies
Kodak Ektapro 9020 Slide Projector Logo
105 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
