Need to know what type interface i'm using with the following two dives so i can upgrade with out expensive mistakes. they are both maxtor and the numbers i have are as follows : c: = 82100d3 d: = 96048d3 thanx ! p.s. can you also help me figure out whether my memory is parity o non ?
    Problem Solver:
  • 17 Answers
C = IDE (also known as PATA)
I can't find the other model documented anywhere but I would suspect it is IDE also.
If this is a desktop it likely does not require ECC ram. In most cases you can use ECC ram in systems that don't support parity checking but not vice versa. ECC memory is generally more expensive. With the computer model number or motherboard model number it could easily be determined if this system requires ECC memory..
Posted on May 02, 2008
I want to upgrade replacement motherboard, what type or measurements size should I try?
ATX is the largest physical size mobo followed by the Micro. You wouldn't need to worry about anything smaller as they are more expensive anyway.
I would be inclined to replace the power supply also as that will be 'tired' and would probably struggle to power the new board. I never fit anything less than a 500 watt power supply. They're not that expensive anyway and it's always better to have power to spare than to be on the borderline.
Apr 25, 2015 | Computers & Internet
I got the old 407291 software version on my machine and would like to upgrade my firmware, but LG says : Contact your dealer --- Please help
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
WARNING: Never update the firmware if the problem you're having is the drive isn't seen by windows, won't write with the included software, or other interface related problems. Unless the firmware specifically states it fixes the problem you are having, firmware updates normally don't fix these types of problems. Trying to update the firmware when there are interface problems can damage the drive's firmware. An error when updating the firmware is usually caused by a problem with the drive interface or there is more than one drive connected to that IDE channel.
IMPORTANT: do not interfere with the drive during the firmware update. If an error occurs during the upgrade process, or the upgrade process is cancelled during this process, damage to the drive can occur. If you experience any problems or have any questions, please contact our LG customer support line toll-free at 1-800-243-0000.
hope this helps
Aug 11, 2011 | LG BH08LS20 Blu-ray Burner
I wish to upgrade my Maxtor 32049H2 HDD (20gb) to a Maxtor DiamondMax 10 6B300S0 (300gb) HDD, The KM400-M2-3.0 Motherbourd specs indicate that the HDD is compatable other than the cabling to the Newer...
The new HDD uses a SATA data interface as well as a SATA power interface. You will need a SATA cable as well as a power supply that supports the SATA power connectors. Since this is an older machine you will probably need to buy a SATA cable and a Molex to SATA power connector. This should cover any cabling issues that you are having.
May 05, 2011 | EliteGroup KM400-M2 Motherboard
Can you let me know what is the maximum installable HDD capacity 0f Lenovo laptop 3000 C100.Can i upgrade present capcity of 40GB to 320GB ?
If you have windows xp with service pack 3, there is no limit. There is no limit if you run Vistaor Windows 7. If you don't have service pack 3, you are limited to 137 gb.
Dec 20, 2009 | Lenovo 3000 C100 Notebook
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
Does maxtor 3100 storage automatically add file to itself?
Yes, it is wise to do a house cleaning on your Maxtor. Whether you delete everything or not is up to you. However, do not do this by formatting the hard drive.
If you find you need a file later you deleted from the drive, a free program called 'FileScavenger' can recover it for you. If you format the hard drive the ability to recover a file becomes highly unlikely.
We techs have expensive software to recover files should you need to get it retrieved, but the interface is designed for techs and not the average user.
Regards,
Worldvet
Jun 08, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
I need a replacement USB interface board for a Maxtor One Touch II.
Hi Dave. I broke the USB interface board inside my Maxtor One Touch II. I am looking to see if I can get a replacement as Seagate are as helpful as a chocolate teapot. If I put the drive into a Freecom caddy, I can't read it. If I connect it to my PCs IDE bus, I can. I shall try another USB interface.
Apr 30, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
