Question about Samsung LN-S4092D 40 in. LCD HDTV
Picture Size I Can't find the right picture size on this Samsung even if go wide panoram zoom1 zoom2 or 4:3 I can't see the bottom or top of the image. Very annoying when you watching a game can't see the score. Can somebody Help me Please have the same problem with the samsung, bottom and top cut off no matter which picture size is selected, forget trying to see banners run across the bottom of screen None of the settings allow me to see the top and bottom of scores, news channel bottom streaming, etc. I've set the picture for WideScreen with Move Up/Down; doesn't work. None of the other settings help either.
  • 7OuterRd May 02, 2008
    If you have your TV connected to a set top box or DirecTV receiver, you may not be able to adjust the screen size using the controls on the TV. Instead, you may have to change the screen size using the controls on the set top box or receiver. See the instructions of your set top box or receiver for additional information.
  • 88 Answers
question how did you connect your flat TV?
if you are conected by the HDMI port you to check your resolution in your config, probably you have to decrease th resolution to 480 P or 480 I to have the totality of the screen.
the format 1080I or 1080P is for DVD player or HD decoder.
if you are connected by component cable, verify in your config menu if you can change the resolution format to 480 P or I
I hope this helps
Please rate accordingly
Thank you
Posted on May 02, 2008
    Brigadier General:
  • 3,614 Answers
Please provide the maker & the model & part # of your unit..
Thank you
  • micromaster
    micromaster May 02, 2008
    any initial check or testing you have done on the unit...?
    have you try to reset the settings you configured there before..
  • micromaster
    well done..!!
Picture doesn't fit screen. A 1-1/2 inch wide band on top and bottom of screen. Have tried the picture button on remote but it only gives me options ie: Panoramic, standard, wide etc. Nothing seems to
Many units will self adjust the image size, but the size of the image you will see depends on what size it was originally recorded in. You can change it in the settings of the TV but most likely it will not go bigger if it was shot smaller.
Feb 05, 2015 | TruTech PVS31170S1W 17 in. LCD Television
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
How do i ajust the picture size to fit the tv?
get the remote... go to menu...roll through to you come to picture / set up here you should see zoom1, zoom 2, normal, wide and panaramic... (note that some shows broadcast in wide screen) top & bottom is cut off...and in hi def the box (picture is showing like a box) all around is black out...don't feel bad I have 56 inch hi def and get mad.... i have 4inches all around all black out if i wanted a 48 .....
just enjoy it Season Greetings
Dec 26, 2010 | Philips 32PF5531D 32 in. LCD Television
How do I change it from wide screen to regular? I have a black area above and below the picture.
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Cannot see words at the bottom of the screen.
i think you should call them first, time warner, i don't see any problem with your try evrything and only this time warner is the only problem.they are sending incompatible tv formats.
May 31, 2009 | Pioneer Elite PRO-1540HD 60 in. Plasma...
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
May 29, 2008 | Samsung Televison & Video
Picture size to wide
I am not convinced that the tv is at fault. The answer may be in the menus of the set top box, if you are using one. If you have cable then put the cable wire directly into the TV to see if the TV is at fault or not. If you have satellite then consider calling your provider to ask if they have a zoom function setting in the box.
Mar 26, 2008 | Televison & Video
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Vizio 37'' TV
This is normal.
Oct 21, 2007 | Vizio L37 Television
Picture Size
Normallly, if the format button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen when an analog signal is detected. It's difficult to determine the repair without knowing the hook up of the peripherals. Hope this helps.
May 13, 2007 | Samsung TXN3071WHF 30" TV
Samsung LN-S4092D 40 in. LCD HDTV Logo
393 people viewed this question
Jerry Greenberg
Jerry Greenberg
