Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Red color halo/shadowing
I just picked up the tv and knew it had this issue with the red bulb. Do I need to replace the bulb and get the tv serviced?
  • Sony Master
  • 8,617 Answers
Can you post a pic of your screen to show the shadowing, as red usually isnt affected with coolant contamination it may be a convergence issue. A pic would help me be better able to help diagnose the problem.
Posted on May 02, 2008
I have a 60 inch Mitsubishi and there are light red shadows in the tv. is this an easy fix
It sounds like you need to re-adjust your convergence. The purpose of adjusting your convergence is to align your red, green, and blue colors. Moving your TV often causes this problem. I hope you get it going.
Sep 02, 2014 | Mitsubishi WD Televison & Video
THE PICTURE ON MY TV IS SHOWING A YELLOW SHADOW ON ON SIDE MORE & A BLUE SHADOW ON THE OTHER. IS THIS A BULB PROBLEM?
TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2011 | Panasonic PT-47WX49 47" Rear Projection...
It looks like the bulbs are not aligned. The upper half of the picture is fine. The lower half has the red above the blue to there is double picture. I just picked up the TV for free. Any suggestions?
This tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have 2 dead STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 13, 2010 | Toshiba 55HX70 55" Rear Projection...
The colors on my TV are shadowing each other in different colors. Such as blue and red.
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Televison & Video
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
PT-53wx53g Convergence issue?
Both convergence amplifiers should have been replaced at the same time. If you can get your hands on a service maual, replace both of them, and go through the convergence alignment in the manual.
Jun 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 02, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Philips 55 inch hdtv rear projector
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Green and red shadows
try adjusting the color purity knob.one by one,or if it is really bad tube u can extend it by rejuvinating it.
Mar 24, 2007 | Toshiba 43H71 43" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
120 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
