Question about Canon PIXMA iP4000 InkJet Photo Printer
Envelope prints the wrong way
I use a pixma ip4000. I am trying to print a #10 envelope but I can't get the printer to rotate the image so it prints correctly onto the envelope (which I have to feed short end first because it's too long to fit in the printer) The printer has an option for this size envelope, but I just can't figure out how to rotate it.
Thanks!
  • arcanepsyche May 02, 2008
    Yes, it's printing perpendicular. Switching between portrait and landscape is not working, that's what's puzzling me. I've tried every setting I can find on the dialogue and the same thing every time.
  • Aziz Chaudhry May 11, 2010
    Are you saying its printing Perpendicular to the envelope instead of parallel?
    Scholar:
  • 79 Answers
This may be a very inconvenient solution but if your desperate then try it. The label you are trying to print : Take a snapshot of it using the print screen button on your keyboard and then paste it into paint. Cut out everything except the label then use the page setup feature in paint to make sure its in the right spot. Dont forget to choose envelope in the page setup and in the printer settings.
Posted on May 02, 2008
    President:
  • 2,712 Answers
Just choose "landscape' from the printer properties instead of the default 'portrait'. Now adjust the margins, etc so that you can position the text exactly whre you want it
PS. Dont forget to rate this Fixya if the solution worked!
Cheers!
Irish Druid
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Choose 'Landscape' orientation, and under Paper tab, select Envelope#10 as the paper size. Now put the envelope in narrow end first, with the flap facing upwards and on the left side.
    Kindly close this thread with a Fixya rating if the issue is resolved. Thank you.
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Cannot print envelope on MX310
    Note:
    • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
    • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
      Note:
    Printer Driver Settings:
    1Select Envelope in Media Type.
    1. Select the size for envelopes.
      * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    2. * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
    3. Select Landscape in Orientation.
    Apr 02, 2009 | Canon PIXMA MX310 All-In-One Printer
    How to address an envelope?
    Use Microsoft Word's envelope address feature (or Open Office).
    Feb 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
    Why cant i print envelopes
    Well that depends, additional info would be great.
    Here's an example:
    PRINTING ENVELOPES from Microsoft Word
    The envelope should be fed into the printer using the short side, all the way to the right, flap to the back and to the left.
    Please follow the steps below to print envelopes in Microsoft Word:
    1. Open Microsoft Word.
    2. Click on TOOLS, then ENVELOPES AND LABELS.
    3. Ensure the ENVELOPES tab is selected. Click on the OPTIONS button.
    4. Select your envelope size under ENVELOPE OPTIONS (ie: #10).
    5. Select PRINT OPTIONS.
    6. Under FEED METHOD, from the six options available select the FOURTH icon from the left. Select FACE UP.
    7. Ensure CLOCKWISE ROTATION is selected.
    8. Under ENVELOPE OPTIONS, ensure you choose the correct envelope size (ie: #10).
    9. Click OK, then PRINT.
    The envelopes should print correctly now.
    Sep 11, 2008 | Kodak Office Equipment & Supplies
    Envelope Feeder is not accepting the command
    > Home > Support & Drivers > Knowledge Base
    Solution --> Phaser 4400 Printer: Printing envelopes
    Printing EnvelopesEnvelopes can be printed from the optional envelope feeder, the Multi-Purpose Tray, or Tray 1, 2, or 3.
    Guidelines for envelope printing
    • Use only paper envelopes.
    • Do not print on the back of the envelope.
    • Never use envelopes with windows, metal clasps, or exposed gummed surfaces.
    • Keep unused envelopes in their packaging to avoid the effects of moisture and dryness, which can affect print quality and cause wrinkling.
    • Envelopes may wrinkle depending on weight and stiffness of the envelope.
    Many applications include a tool for creating an envelope document. For example, Microsoft Word includes an Envelopes and Labels feature in the Tools menu. Be sure to:
    • Select faceup.
    • Clear Clockwise Rotation.
    • Select the feed method with the image centered and the stamp on the envelope to the upper left.
    caution_image88x30.gif Never use envelopes with windows, metal clasps, or exposed gummed surfaces; they can damage the printer. Damage caused by using unsupported envelopes might not be covered by your printer's warranty.
    note_image33x30.gif Note: The heat from the printing process can melt certain types of envelope glue. If the envelope flap sticks shut after printing the test print, tuck the flaps inside the envelopes when printing the remaining envelopes. Printing envelopes from the envelope feeder
    1. Insert the envelopes into the envelope feeder. For more information, refer to the Trays section of the Trays and Paper Guide on the Interactive Documentation CD-ROM.
      • Place the side to be printed faceup.
      • The top of the envelopes should be toward the left of the printer.
    Feb 19, 2008 | Xerox Phaser 4400B Laser Printer
    PIXMA 830 Smudges when printing envelopes
    On my MP780, be careful to select the appropriate paper type; I was getting black smudges on the left side of my envelopes until I explicitly set that my paper type was "envelope" from "plain paper".
    Another idea is to adjust the "ink drying wait time" to a higher level.
    Dec 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
    Canon PIXMA iP4000 InkJet Photo Printer Logo
    301 people viewed this question
    old marine
    old marine
