Back to:
Tags:
Acer Aspire 5670  PC Notebook
Acer Aspire 5670 laptop base too hot. (by 2 users)
posted by gracylibob on May 02, 2008
Bottom of laptop gets too hot to set on my lap when on. I've never had a laptop get this warm before.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Aug 31, 2008
i need a sound driver formy 5670 ASPRE. Can you help me?
Best Solution
posted on May 02, 2008
FixYa! (100)
cessna152
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
this is normal but be carefull it will damage your graphic unit
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Acer Aspire 5670 laptop base too hot.:
I don't want to Accept this solution
Solution #2
posted on May 17, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
IF the fan is loud, too then it seems to be dust inside open the biggest cover part. But be carefull the lap doesn't have power. Remove the battery pack first. On the right side where the power button is located, there is on the botton side of the laptop the cover part, which i mean. open it there are FAN, RAM clean it with a vacuum cleaner low-level.
Thank You!
Solution #3
posted on Jun 05, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
thanks
Thank You!
Can you Help with these PC Laptops problems?
PC Laptops
My laptop has Windows Vista Ultimate x64 as its operating...
PC Laptops
I don't really have any problem with the laptop now... I...
PC Laptops
Pls help me to find SATA drives to be integrated on XP...
Acer Aspire 5670 (LXAA706003) PC Notebook
When turning it on from the tower it goes to a white Acer...
What settings do I need to change to connect my Acer...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
