Rank: Guru
Rating: 88%, 1793 votes
You can find the remote control codes for difrent brands of
devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
- PRESS
the button for the device you want to program, (TV, VCR, CABLE, etc.),
then RELEASE.
- PRESS
and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
- ENTER 9-9-1 (two blinks on the remote)
- ALTERNATE
slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.)
button until your device turns off. (On VCR, LD, and CD players use PLAY
instead of POWER)
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
- When
your device turns OFF, PRESS the SETUP button and RELEASE it to lock in
the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
- PRESS
and HOLD the SETUP button until the red LED flashes twice.
- PRESS
9 - 7 - 5, the red LED will flash twice.
- PRESS
the DEVICE key where you wish to learn the function. The next 3 steps must
be completed within 10 seconds.
- PRESS
the button that will receive the learned function, the LED will flash
radidly.
- PRESS
the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programing your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just
yet. Please post back as to what steps you took, results, etc, and I will try
to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Comments:
May 31, 2008
- Hi,
Just wanted to inquire if your issue is resolved, or if there is anything
further I can do to assist you…
P.S. -You can rate this solution with one of
four votes, if you feel your issue is resolved.
- "FixYa!"
- The solution provides great advice on how to solve the problem.
(Positive Rating)
- "Helpful"
- The solution provides useful leads that helps solve the problem.
(Positive Rating)
- "Thanks
for Trying" - The solution does not solve the problem but the
effort is appreciated. (Negative Rating)
- "Inappropriate"
- The solution has absolutely nothing to do with the problem. (Negative
Rating)
If your issue is not still not resolved, do not
assign a rating just yet. Please post back as to what steps you took, results,
etc, and I will try to assist you further as best I can.
IrishDruid
