Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Transmitting My HT 1000 recieves but will not transmit. Help! Thanks.
Check the antenna, this is especial and the conector in the base is longer than other. You will probe whit a wire of cooper as antenna : Good Luck
Posted on May 28, 2008
  • 47 Answers
Read the radio on the computer and see if the TX is enabled.
Also the PA could be faulty
Posted on May 26, 2008
Realistic trc 443 cb quits transmitting and recieving
Sounds like the weather alert system is getting activated.
Jul 26, 2010 | Uniden PC78ELITE 40-Channels Base CB Radio
HT-1000 has low Tx audio and programmed PL doesn't
While there are some adjustments which can be made in the RSS, doing so would not necessarily solve your problem, as it may create another. These setting would require the radio to be adjusted by a service tech using a service monitor. Your PL problem may simply be a programming issue. Double check the PL setting in the radio, also check to see if it is to be inverted or standard PL. If your radio is Transmitting low to other units, you could also be mixing narrowband and wideband radios. If so, one will talk softly to the other, while the opposing radio will be very loud talking back (among other things). And one other simple thing to check when having Tx issues is the antenna. Be certain you are using the correct antenna, the antenna is free of dry cracks or damage; and the antenna is attached properly.
After checking all the above, if you do not solve the problem, contact your local dealer or service center.
Best regards.
Sep 19, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Uniden Oceanus not transmitting
You may have a sub-channel/privacy channel activated. Unless the person/s you are trying to talk to have the same channel and code set they will not be able to hear you. Check your manual for specific instructions on how to reset it to the default.
Jun 11, 2009 | Uniden Oceanus DSC Wham ready Fixed Mount...
We have 4 T8500 - only one can talk, the other 3 only recieve.
Can you tell if the radio is actually transmitting? Is there any sound on the transmitting radio or a light inditcating that it is indeed transmitting? If not maybe the PTT button is malfunctioning. Try to use a microphone plugged into the accessory jack and see if it works. Another option is if you have a radio scanner, search the frequency range while transmitting and see if you pick up that open carrier.
Feb 24, 2009 | Motorola T8500 Two Way Radio
Radio stays transmiting after mic released
What happens if you "key up" and "let off" and the transmitter "hangs", you remove the microphone plug from the Cobra ?
Will it still be transmitting or will it stop ?
If it stops, the problem is in the microphone with a "hanging" switch which you can easily clean or replace.
Iif it keeps transmitting while the mike is disconnected, there is a problem with the Rx/Tx switching circuit. This needs further investigation by use of a circuit diagram.
Feb 13, 2009 | Cobra 29 LTD CB Radio
SL55 Not Transmitting/Recieving
the two radios are on different CTCSS Tones
Feb 01, 2008 | Maxon Radio SL55, SP130, SP140, SP150...
Transmits by itself
Check if the VOX features is turned on, check if the Ptt button has the "normal" bouncing or clicking.
Apr 26, 2007 | Uniden Voyager 2-Way Radio
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
88 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
