Cars & Trucks Logo
Posted on Aug 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 95 corolla will not start. When I put the charger on the battery it says the battery is fully chared. When I put the charger on quick start the starter clicks and grinds but doesn't pull in to turn the engine. could my battery still be bad? Or is it the starter?
Duane Wong
Level 3:
  • Toyota Master 6,826 Answers
  • Posted on Aug 17, 2010
Duane Wong
Toyota Master
Level 3:
Answers
6826
Questions
6
Helped
2859406
Points
20233
OK, if the battery has 12.5 volts or so, the charger will say it's fully charged. But, the real test is to load test it and check for CCA which should be like 550 CCA and above for most cars.
You could purchase a new battery from Walmart, an auto parts store, or Sears, and before you purchase it, have them test the old one to see if it is bad or good.
Once, you have a known good battery, then you can try it in the car. If it just clicks and grinds but doesn't turn the engine over, then you know you have a bad starter in the car, which will have to be changed.
2007 Honda crv 2.2 diesel,difficult to start after being left a few days.
When cranking it seems like no diesel getting through. If I tow it down the road it will start almost straight away. AmanStino QUICK CHARGER 3 0 USB charger Multi Port Intelligent USB Wall...
How do I set the settings on my NAPA automatic starter/charger to charge my battery in the car or to try to use it to quick start the car battery? Both ways to set the starter/charger would be helpfu
Put it on medium or the quick charge. If it has a start or boost on it put it on that and try to start the car. Do not leave it on a high rate (start or boost)for long periods or the battery could explode.
Any does my 95 Corolla always need a quick boost to start
Alternator or battery may be the issue. If you have an AutoZone or other parts store they may test either for free.
TAZZ SOMETIMES DOES NOT WANT START
Sounds like you need to get your battery fully charged on a battery charger and then tested at a garage. Driving will put some charge in your battery but not fully charge it. After your battery has been flat it is less likely to fully recharge and the alternator is designed to keep the battery topped up rather than fully charge it. Jon
2007 is250 battery died, then was fully chared, now the car isn't detecting the key and won't start
all new cars are set up that if the battery deads it goes into lockout mode. it is so the dealer ships can make money
Flat battery central locking cannot open
Raise the vehicle & put a battery charger on the starter
battery cable terminal & ground the other charger lead
to sub frame or motor to charge battery if it will take a charge
I was charging my flat car battery using a selmar gaurdian professional battery charger, the fully charged light came on after about halfe an hour, i don't know if the battery is charged as i have not put...
if the charger is rated at 10 amps or more yes,it received a 'quick charge' enough to render it serviceable.the charger should be 'overcharge protected' so you could give the battery another 'zap' just prior to installation.
Mazda RX8 starting problem
Check that your battery is fully charged. If it does not sustain a charge , replace it. Clean the cables and battery posts with baking soda and water mixture. About 1/4 cup to a pint. If it still does not turn with a fully chared battery, it is probably the starter that is bad. It will have to be replaced. One click usually means the starter is bad. Several clicks usually means the battery is bad.
2answers
BMW 323i no power in the car at all, not the battery, not the alt
I think the earth lead from the battery to the body may have come loose or come off. Its worth a quick look. good luck
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
