Question about Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio
COBRA PR4700WX WHEN I TURN IT ON AND TRY TO PROGRAM IT ALL IT SAYS IS POWER SAVER AND IT WILL NOT LET ME DO ANYTHING. WHAT CAN I TRY??
  • Power Saver Jun 11, 2008
    WHEN I TURN IT ON AND TRY TO PROGRAM IT ALL IT SAYS IS POWER SAVER AND IT WILL NOT LET ME DO ANYTHING. WHAT CAN I TRY?? The lock button is NOT on.
    Sergeant:
  • 250 Answers
Hello horndog78,
Your radio may be locked. You can confirm this by looking for a icon of a padlock on the screen.
To toggle the lock on and off hold down the LOCK/MODE button for a full two seconds until you hear a double beep.
Best Regards,
Ken
Go Ahead. Use Us.
Posted on May 05, 2008
  • Andrea Steward
    Andrea Steward Apr 29, 2016
    This helped me too! Have been pulling batteries every time to turn my walkie talkie off. THANK YOU!
What mode do i charge my cobra micro talk walkie talkies on
the ones I have came with their own charging stand cup bases & rechargeable batteries, they are impressive radios as compared to others I have & they have NOAA channels as well
Dec 27, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
Why is the power saver message flashing? its fully charged
It's because the designers thought you wouldn't trust that the battery saver function if it didn't flash or otherwise tell you it's working, I think it's directed toward the small child market.
Dec 12, 2014 | Cobra Microtalk 100 FRS Walkie Talkie...
Cobra microtalk
Please mesure the battery voltage first...then get the service manual and check if there is an smd fuse right next to power pushbutton....please inform me for any progress...thnx..
Feb 24, 2014 | Radio Communications
Lost the manual haw do u turn radios on?
Press and hold the MODE/POWER button (top button right of the display) to turn the radios ON or OFF. Need the manual? You can download/print it here:
http://cobra.com/downloads/manuals/Cobra%20Manual/COBRA_MANLS/GL_MANLS_WEBSITE/GMRS/PR190_MANL.pdf
Dec 30, 2009 | Cobra microTALKPR 190-2 Two Way Radio
No Auto Squelch on Cobra PR4700WX
Yes sir, when u will open the set u can find two potentiometers , one is for tranmitter another for receiver . Try adjusting the same ( second radio should be transmitting ) do not switch one radio without antennae it may burn ..
Regards
raj/
Dec 24, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Help
Hi again,
It would seem that you posted twice. As responded to in your other post, the manual is here.
Cheers.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Cobra PR4700WX -none of the controls work
If you find that the LOCK/MODE button does not correct the problem, I have discovered that the microphone button on the inside has a contact patch mounted on the board. This contact patch is like a piece of scotch tape with a metal dot in the center this slides off to the side and leaves the MIC deppressed continuosly which in turn will lock the radio. I have found this on several radios. Once you center the patch place just a small amount of super glue to the edges and yo will have no more problem
Jan 06, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Cobra MicroTalk PR 1100 WX (15 Channels) 2-Way Radio Logo
675 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Iron
Iron
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
