Question about Kenmore 43142 Front Load Washer
Kenmore Energy Washer front load - about 5 - 7 years old
I put 3 bathroom rugs in the washer and first I noticed all water on my floor so I think it was coming from where the black water hose attaches to the water pipe so I taped in with electrical tape.. Then, I started the machine again where I left it and then the water would not drain, at all....I took out the wet rugs and I noticed that alot of rug material seemed to be probably clogging something in the machine. I took a wet vac and vacuumed out the machine and noticed that alot of the rug material seemed to be stuck under the tub grid......help....what do I do....mkmsales2@comcast.net
  • 172 Answers
Hi mommo2,
I really hate those little rubber pieces that come off of those rugs, they really gum up everything. Just for future reference try to wash those outside with a water hose and a scrub brush. It will save you lots of money in repairs.
As for your current problem try to get as much out of the tub as possible. Then you will have to remove the small kickplate on the bottom of the washer. Get you some towels and a maybe a flat pan to catch some water. The panel will have a few screws around it that will need to be removed. Once you have removed the panel you will see your pump. The front of the pump has a filter that can be unscrewed and removed for cleaning. Unscrew the filter and get ready to catch some water. Maybe as much as a couple gallons. Once you have cleaned it out put the filter back in the pump and leave the panel off. Run the washer throught another cycle and clean the pump out again. You may need to repeat this several times. Hopefully this will solve the problem, if you still have draing issues you could have a clogged drain and for that you may need a plumber. Well good luck to you and I hope I helped. Mike Anderson mca0824@aol.com
Posted on May 02, 2008
Washer capacity of kenmore 4906 4907 ie 5.0 cu feet
The Kenmore 592-4907 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
The Kenmore 592-4906 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
This is the Specs website despite the title :>)
teachmefinance com
Mar 24, 2017 | Kenmore Washing Machines
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
F21 code on kenmore he2 plus
Clean the filter in the pump behind the bottom panel,but remember it's full of water,If it's on a pedestal you can take the pump loose from the mounting pull it out a little and put a small pail or bucket under it before you open the trap.if it isn't on a pedestal it's a bit more challenging unless your in a basement with a floor drain. Open it very slowly and let the water drain a little at a time don't take it all the way out or you'll be in for a flood....good luck
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
My Front End Load Washer does not drain
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jun 12, 2009 | Kenmore Elite 45986 Front Load Washer
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
I have a Maytag Neptune washer. I`ve had it about ten years and Ilove it. today I washed a bathroom rug that is old and the backing has come off. Now the washer will not empty . Even when the cycle was...
sounds likeyouve problably clogged your pump assy with the backing of that rug. all you can do is clean out the pump assy,
1. drain out as much water as you can(buckets, cups , etc)
2. the door comes of by removing 2 screws on the hinge, and remove the 2 screws on opposite side of hinge.
3. the front "U" shaped panel will kinda wiggle and pop off.
4. UNPLUG THE UNIT.LIVE WIRES!!!!!!!!!
5. youll see the pump assy 2/3 thirds the way back on righy side. youll need to remove the clamps holding the hose on and remve the debris from pump housing.when oyu relese that clamp theres gonna be some water still in hose so prepare for might be as much as a gallon or so. plus all the crap you got stuck un there!!!!
6. reassamble and start washing!!!
Mar 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 43142 Front Load Washer Logo
137 people viewed this question
Sal De
fordexpert
Robert Rankin
