I try to print my document directly to the sharp ARM276 but it goes to another computer and prints from there
    Scholar:
  • 176 Answers
YOu can checnk in the printer section if the Sharp printer it is the defualt printer maybe the other printer in the network is set to defeault printer. Click PROGRAMS, PRINTER AND FAXES then right click the SHARP printer and select SET AS DEFAULT PRINTER and try to print again.
Posted on May 02, 2008
Why can't I print PDF to my personal folder on our sharp MX4111N printer. We can print pdf files directly but we can't store them in our folders for later printing. When we try the print to the main...
You would have to create the folder in the web page that you wanted to print to, then tell your print driver that's where you want it to go.
under document operations in the web page, create a custom folder.
then in your print driver, go to the job handling tab, check the retention box, and where it says "stored to" choose the custom folder you created.
www.equipmybiz.com
Jul 30, 2014 | Sharp MX-4100N Copier, Printer, Scanner...
Sharp MX-2610N printer can't set-up the print job (for labels from by pass tray) from my desktop computer.
Some documents like word override the settings... you need to change/save within your document you are printing. page layout and then page set up
Sep 16, 2012 | Sharp MX-2300N Color Copier
Ping works, I can see the html page in the AR-205 but can't print
If you connect the machine to network via AR NB3 and EB 9, go to key operator program in the html page, hopefully the password still the default "Sharp", try test page printing. Also check the account control from the machine's panel by pressing special function, key operator program, password ( 00000 ) account control and un-check the account control for printer.
Jun 06, 2009 | Sharp AR-M205 Copier
Printer will not copy although we can still print documents sent from the computer.
Is it infax mode?
Do you get a green Start Button?
Are there any error codes diaplayed when you push the button?
If no to these, unplug the machine for several minutes and restart.
Hope this is of some help
May 19, 2009 | Sharp Office Equipment & Supplies
I got sharp printer which is not printing PDF papers. could you please helpout.. please..
If you're trying to print out PDF's directly off a web site, this could be your problem. There's coding anomalies between web pages and imbedded PDF's that can cause some printers to lock up, show error codes or simply not print the screen out. You may want to avoid these web page PDF's as to my knowledge there's presently no solution to directly print these out.
Also, if the document is first in line in your print queue it can block any other documents from printing, so you'll need to delete the PDF from the queue.
Apr 06, 2009 | Sharp AR-M205 Copier
CHANGED INK, WON'T PRINT.
Try to reinstall software restart pc when it asks if the cartridge is new say yes
Mar 25, 2009 | Canon PIXMA MP600 all-In-One InkJet...
TLP2844 won't print
Hi David,
Default the printer so you have a green light.
Print a configuration label so you have the printer's settings.
Check the document you are trying to print.
If your "normal document" is using PCL, it won't print because you aren't speaking the printer's language.
Make sure you are using a Zebra driver and that the label/media settings match your printer. Look at your direct thermal/thermal transfer setting and your media length setting -- especially continuous vs. non-continuous.
Sep 21, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Sharp AR-5320 Copier giving L 4 error alternately
The only way to corret the problem is to replase the fixing unit... That is what the L4 is refering to. It is not reading the correct tempurture..
Sep 20, 2008 | Sharp AR-5320 Black and White Copier
Printing
Disable printer spooling in the printer properties and enable direct print
May 14, 2008 | Sharp AR-BC320 All-In-One Led Printer
Epson Stylus CX5400 prints bands of color
directly hooking the printer to mac and windows computer are you getting bandings still? interesting issue... we will isolate it first by trying to hook printer directly to both computer, if its printing fine when directly connected, then there is something on the application or communication process. try printing a different document using same application when on the network and try printing from different application as well. update me afterwards..
Apr 03, 2008 | Epson Stylus CX5400 All-In-One InkJet...
jasbo
jasbo
