Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Dew light sharp camcorder
Hi  My name is frank i am from canada
I can not use my camcorder anymore cause a dew message appears all the time and the camcorder shut down after few second? can someone help me ?
I appreciate a lot.
  • 3 more comments
  • helenman Jun 19, 2008
    Hi
    Yes I have the same problem, but it will eventually fix itself. Can you tell me the cause and a solution. It seems to happen more when I was overseas, with the changes of temperature and air conditioning & also on the plane.
    Please help
  • responsehamm Jul 29, 2008
    I turn on the camcorder and it shuts off..even when plugged in. It does say dew.
  • Anonymous Sep 04, 2008
    dew indicator comes on an shuts down camera
  • Anonymous Nov 03, 2008
    I had the same problem, I wondered if it was the old tape but this link did fix it, I ended up soldering the dew sensor pins together as a last resort and hey presto, it works, thank a million, the power of the web is awesome!!
    See the link http://ataplow.googlepages.com/sharp-dew...
  • yorki Dec 07, 2008
    i have the same problem-its so annoying when you want to tape something at the spur of the moment and it wont work because of the dew sensor.i have way of getting round it without welding the sensors together-i open the side where you put the tape then rest it on top of the radiator while its warm,place the camcorder upside down so the warm air goes into the camcorder-you,ll have to leave it there for about 20 mins,but it will work-you can also do this trick in the car by placing it on the dashbord while you have the heating on-it should be ok by the time you reach your destination
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
Sep 13, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Dew light
Dew is likely to form in the following circumstances: ?When moving the camcorder from a cold place to a warm place. ?When placing the camcorder in a cold room which is then heated rapidly. ?When moving the camcorder outdoors from an air conditioned room or car. ?When placing the camcorder in the direct path of air blowing from an air conditioner. ?When placing the camcorder in a humid room. Dew will gradually form on the head drum of your camcorder and make the video tape stick to the head. This causes damage both to the head and the tape. When dew forms, recording and playback may not function properly. When ?DEW? flashes, remove the cassette,leave the cassette compartment open,and wait for a few hours to allow the camcorder to acclimatise to the surrounding temperature. To use the camcorder again, turn on the power after waiting for a few hours. Be sure that ?DEW? has disappeared. Do not insert a cassette while ?DEW? is flashing; this may result in damage to the tape.
Aug 03, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
DEW message keeps coming up on camera
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 22, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
"Dew" sitting on my Video Camera
Dew Formation
What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
When dew forms in your camcorder.
circumstances:
—When moving the camcorder from a
—When placing the camcorder in a cold
—When moving the camcorder outdoors
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
“Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
camcorder to acclimate to the
2To use the camcorder again, turn on the
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
Mar 13, 2009 | Sharp Viewcam VL-Z5U Mini DV Digital...
Shut down "dew"
This happens when you take camera from cold(er) environment to warmer environment, dew forms on the recording head, so as a precaution the unit locks up. The solutions is to leave the unit switched on and wait till the dew incator goes out( can take up to an hour) I found this out when on holiday, i would go from an air conditioned room to bright sunshine and it happened all the time.
Sep 28, 2008 | JVC Everio GZ-MG30 Camcorder
Dew warning message
Dew sensor is defective and you need to replace it to fix the problem.
Jul 25, 2008 | Sharp Viewcam VL-Z5H Mini DV Digital...
Camcoder
There have been several compaints about this dew issue. I recommend calling Sharp.
Support: (800) 237-4277
May 03, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Dew liht comes on and camcorder shuts off Everything was ok when suddenly the dew light appeared and the camcorder just shut off. Suggestions as to what to do... Do you think if I tried resolving the...
Tools needed. Zip lock bag. Sillica packs from shoe boxes or find somewhere to buy more... SImply seal with the camera and wait a couple days. This will suck the dew out. :) DO NOT USE HEAT like from a hair dryer or anything like that. Too hot for a cam to handle.
I had the same problem with a VL-Z3U, there was no home fix, the dew sensor needed replacing costing $130 CAD
Jun 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
318 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
