Question about JVC AV-65WP74 Rear Projection Television
Convergence IC"S I changed the ic's in my JVC- AV-65wp74. it helped the sagging but did not fix the problem. some of the solder points on the board looked as if part of the board seperated from the board. i am thinking this is the problem as when i soldered the new ic in place the solder did NOT bond as well as the others!! What should i do next. Replace the board maybe??
  • Tim Buckley May 04, 2008
    About Six months ago i changed the IC's in my JVC.. AV-65wp74. The TV worked better but not perfect. When i soldered the ic's in i noticed that on two of the spots that recieve solder did not bond with the solder as well as the others.. I tried to resolder them at least twice each, the solder did NOT bond as well if at all to the board. Should i just replace the board??
    Master:
  • 377 Answers
You change/replace the board, it is useless for you anymore... it will not do..
Posted on May 04, 2008
    Genius:
  • 1,142 Answers
All you need to get is flux from any of the pc repair shop and use the paste along with the soldering wire to get the oxide out which will help you to get the solder done correctly.
  • Maanita Chadha
    Maanita Chadha May 04, 2008
    Please dont rate helpful in case it didnt leave it blank or rate fixya. thanks
  • Maanita Chadha
    Maanita Chadha May 07, 2008
    Before you replace the board why dont you resolder the component you might not have to replace then.
  • JVC Master
  • 13,433 Answers
Hello tbuc
I supose the easyest way to solve the problem would be to replace the whole board.
as you have already tryed to solder them again and again.. I'd say do it again, and while your at it check if any other components might be bad, capasitors etc etc..
If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
    Brigadier General:
  • 3,614 Answers
Not unless you damaged the board, & theres no part of it have to be soldered and circuit is damaged, then it could be needed a new board.. but try to check if theres something to correct into your soldered parts and correct it again using a soldered pump to remove the bad solder.
thanks
Posted on May 02, 2008
  • micromaster
    micromaster May 04, 2008
    not unless you don't need solution, instead you want suggestion..
    you may replace the board, if that's what you want..
  • micromaster
    clean & scrub the surface, for you to make the solder lead stick
Blue lines arc down from the top of the screen on JVC IART TV model number AV-65WP74. Is it worth fixing? Thanks
Yes it is worth fixing . You can fix it yourself for about $ 21 . You need to replace the convergence I.C. chips , The part # is STK392-310 . you need two of them . You can get them from bluestar-online.com . They are about 6 bucks a piece and about 10 for shipping .
May 13, 2010 | JVC AV-65WP74 Rear Projection Television
How 2 fix JVC AV-65WP74
Sounds like a vertical IC failure. I would try replaceing the IC that may repair the issue.
Dec 31, 2009 | JVC AV-65WP74 Rear Projection Television
We have a problem with the ghosts. double people and colors are all over the place. went to convergence and tried to enter to go to auto or even manual but only got lines of different colors can we fix...
Need a repairman - unless you've done soldering and electronic component replacement b4.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74
Hi, sounds like your convergence IC`s have failed if one of the colors doesn`t adjust either up/down
or left/right. If you have soldering equipment and are very proficient at soldering you can replace them. if not you definitely need to call a tv tech, if you need more info ask away, video-tek
Jan 26, 2009 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 Blue, Yellow, Green curves on screen. Double Images. Help Please
Pin cushion distortion. It is an internal circuit fault. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 11, 2017 | JVC AV-65WP74 Rear Projection Television
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
have pts rebuild the board which will cost around $130, www.ptscorp.com, or replace the stk392-110 x 2 located on the convergence panel.
Dec 08, 2007 | JVC AV-48WP74 48" Rear Projection...
PCB's when available,are expensive.Replace convergence IC(s),
re-adjust and you are good to go!
Oct 12, 2007 | JVC AV-65WP74 Rear Projection Television
JVC AV-65WP74 Rear Projection Television Logo
46 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
