Question about Car Audio & Video
Cd stuck my tundra cd player has worked great till yesterday...i ejected the old cd's without a hitch..the first new one went in fine but the second would not load..tried eject the first cd but the changer seems to be stuck...i'm getting a system 3 error now and there is no help from the trouble shooting section in the owner's manual...the thought of taking it to a dealer sucks... thanks for any help!!! al
5 Other Users Have The Same Problem Comment by babba booey, posted on Jun 26, 2008before you spend $$ to have someone do anything, take the radio out of the dash yourself. what;s the worst thing that can happen, you break the radio that doesn;t work?
take the top of the radio apart and move the cd around... it's jammed and needed help to set up in the player.
put it back in the dash and push play. it should work. i just fixed mine and i am happier than paris hilton in a sausage factory.
Posted on Jun 27, 2008
The CD player/changer in my car is not loading or ejecting the CD's. When I push the load or eject button, it makes a grinding sound. It was playing fine yesterday but since I left a CD inside the CD...
I just acquired the same problem. I tried to put a new CD in and it wouldn't take it. I ended up pushing it in when I was trying to get it back out and now it won't play the CD, or eject it. I think it could be stuck between tracks, but they want $188 to look at it and fix it even if it is a simple fix. I am looking for suggestions also, Diane
Mar 13, 2010 | 2003 Mazda Mazda6
CD will not eject from unit.Word'IN' keeps
you can try either pushing the reset switch (which will be a small indentation either on the face or the subpanel behind the face) or disconnect power to the radio for a few seconds.
Nov 30, 2009 | Car Audio & Video
CD player is not working.
I would first try removing the fuse to the radio/cd player, see if that resets the system and get the cd out.
Hope this helps some.
Matt
Jun 19, 2009 | 2003 Mazda Mazda6
DVD disappeared in DVD Player after viewing movie
Get the dummy cd disc, put a blue tac on it. Insert it. Then after few seconds, eject it. Your dvd disc should stick with it when they came out. It worked for me and hope it will work for you.
Jan 31, 2009 | Kenwood DV-505 Multi-disc DVD Player
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
Stuck on start screen
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Then get the firmware upgrade
Jun 24, 2008 | Philips GOGEAR SA6045 MP3 Player
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    2000 Toyota Tundra Limited truck 5 CD player will not play change or eject CD'S. Radio and Tape player work fine. How do I remove Unit to see what is jammed or hung up. At least to remove CD's?
    try slipping a thin plate like a putty knife down both sides of the radio. This releases spring clips and the radio should slide out.
    May 24, 2008 | Car Audio & Video
    Toyota dashboard CD player won't eject
    I had this say problem with my 2000 solara. Here is the fix, remove one of the car battery terminals for a couple of mins (3-4mins). The reattach the battery terminal back. This would make your cd player and car clock reset. once you start your car you should be able to eject the cds. You'll just need to reprogram all your preset radio station. Hope it helps
    Oct 04, 2007 | 2003 Toyota Celica
    Cd ejection
    Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
    Mar 13, 2007 | JVC KD-S680 CD Player
    Car Audio & Video Logo
    170 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
