HOW to hookup,connect, dvr cablebox to DVD,VCR Recorder(Panascnic)threw HomeTheater ?
    Scholar:
  • 79 Answers
Connect cablebox output video cable to DVD recorder input. Connect Audio cable to Home theater. Connect DVD Recorder output to TV.
Hope this helps!
Posted on May 02, 2008
How do I hook up dvd player with a cablebox?
Most TVs have several input selections on the back so you don't have to go thru the cable box. Look thru your TV owners guide for the best choice
Feb 03, 2012 | Cyberhome DVR 1600 DVD Recorder
How do i record from directv hddvr plus to my vcr or dvd
Your going to need a AV connection out of the DVR into the DVD or VCR, whichever you want to record to. Go with the highest quality cable you can because that will define the quality you end up with. If you have an HDMI connection out of the DVR and an HDMI connection into your DVD Recorder, that is definitally the way to go.
Oct 25, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Connect a Dish VIP622 to a DVD/VCR
Hi piautewith the VIP622 receiver connecting to your DVD/VCR player you will need theinput/output jacks. To setup recordings to your VCR/DVD player, you will want torun from receiver output to VCR/DVD input and from VCR/DVD output to TV input. Thefan on the VIP622 receiver is just like the fan in a computer tower. Even ifthe receiver is off the fan will still run to keep unit the right temperature foryour DVR receiver. MikeHouston of DISH Network
Oct 18, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Want to burn some movies off my dvr
http://www.usersmanualguide.com/
see if theres a manual here
Apr 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
I have a ViP 722. It has no rf output for TV1, just the hookup for TV2. The multi RCA hookup for HD. HD is not as important to me as is a clean picture and audio on my TV. No matter how I do it, I get a...
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
Dec 06, 2008 | DISH Network DVR-625 DTV Receiver /...
60hz hum
I sent a solution to this already. If you did not receive please let me know. Thanks for using Fix Ya.
New TV hookup
Erica,
You should have no problem with this. I have provided a picture of your model below for clarification. One end of the coax will attach to the 3-4 OUT on the back of the receiver and the other end will go to the NEW tv's coax input. If your set has two coax inputs you may have to select the port that you connect to in the menu portion of the tv. If the new tv does not have a coax input you can use RCA jacks which are red/white and yellow and connect those to the TV 1 output on the back of the receiver and the other end to one of the inputs on the back of the tv- this will require you to select the input source you connect to again e.g AUDIO 1, AUDIO2 etc. If you have a VCR run the coax from the 3-4 on the back of the receiver to the antenna inon the back of the VCR -usually the top port, then run another coax from the output- bottom port to the coax input on your tv. I hope I have been of some assistance to you and Thanks for using Fix Ya. If I can assist you further please let me know.
Jim
Apr 06, 2008 | DISH Network DVR-625 DTV Receiver /...
PioneerDVR-225 recorder
A lot of the functionality you are wanting is tied to the remote that you have misplaced. You can go to the Pioneer support site and order a new remote, though it is like $30.
As for wiring options to record, it depends on the inputs and outputs that are available on your television.
- Ideally, connect VCR to TV input "1", connect DVR output to TV input "2", and conect TV output to DVR. This will help you avoid any copy protection issues you run into, but not all TV sets have both audio and video output.
- If you don't have TV outputs, connect VCR out to DVR in, and then DVR out to TV in. This will definitely work, but you will have to have the DVR turned on to watch a VCR tape.
Nov 24, 2007 | Pioneer DVR-225 DVD Recorder
Need a VCR???
You should just be able to replace the vcr with the DVR and connect it in exactly the same way, unless the vcr is very old and doesn't have the same connections. If you want exact info, please post back with the make and model numbers of your TV and cable box and we should be able to talk you through it. Hope this helps, if not please post back with the details :)
Apr 23, 2007 | Panasonic DMR-ES10S DVD Recorder
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
