Question about Refrigerators
Danby Silhouette Wine cooler won't cool. Need to know if I can fix it (freon charge maybe?) of if I should call someone to service it.
  • Canonchet Jan 10, 2009
    it has just stopped cooling. the fridge motor does not seem to be working.
WHAT STORE CAN YOU FIND PARTS FOR DANBY WINE COOLERS. THANKS FOR THE INFORMATION. MY E-MAIL IS beyat2@bellsouth.net
Posted on Oct 01, 2008
  • 172 Answers
Hi sooner84,
I really like the Danby wine coolers, they are usually nice products. As far as your problem, I would first try to find out where the main problem area is. To do that first make sure that your compressor is running. If the compressor is running and it is not cooling then you may have a freon charge issue. Thats not to say that you can just put some more freon in and it is fixed, You would have a leak in your sealed system and you would most likely still have warranty coverage for that. Most Danby products carry a 5 year sealed system warranty. That would include your compressor.
If the compressor is not running then you would know that you have a compressor issue. Either the relay overload on the compressor would need to be replaced or the compressor itself was bad. You can buy relay kits for about $30.00 and intall them easily with very little experiance.
Next if the compressor is doing its thing and trying to cool you could have a fan not blowing air properly. either a condenser or evaporator fan may have stopped. If you find one not working then chances are you just need a fan. If the fans are blowing and the compressor is working then you would just have a defrost problem. In that case you would just need to defrost then check for bad parts, either a defrost heater, defrost thermostat or a defrost timer. Most of the Danby products have a defrost control board, that board willl contorl the defrost, the temperature, and the fans. If the board was cheap I would say just put one on and see if it fixed the problem, but they are around $145.00.
The most important thing for you would be to make sure you are not going to do something that would void your warranty. Free service is always the best. Good luck to you and send some wine my way, I make lots of different types. from grapes, strawberrys, muskedyne, etc.... mca0824@aol.com
Posted on May 02, 2008
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
I am looking for the cooling fan for a Danby Silhouette DWC512BL-1 wine cooler. A google link took me to your site but I don't see any links to Danby parts.
As I have worked on a few ELECTROLUX wine coolers and they do not have a cooling fan for the inside of the unit are you speaking of the one under and in back of your cooler if so then it is a condenser fan motor it will be 110v and your local appliance store should be able to order one close enough to work in design and rotation of it. Hope this helps.
Apr 09, 2011 | Danby DWC513BLS Wine Cooler
Danby wine cooler model dwc172bl thermostat replacement
Once I figured out there were black plastic caps covering the screws holding the inside back panel in place, it was an easy fix. The cooler is now up and running. Thank you for giving me the $10 incentive to figure it out myself.
Jan 18, 2009 | Danby Silhouette DWC512BL Wine Cooler
Danby Silhouette DWC513BLS lower back fan noise.
Called Danby customer service. Requested repleacement part of lower fan unit. Located at bottom right on back of unit. Part was $6.68 plus shipping. Less than $10 total. At my door in 3 days. Plug and play piece that was easy to change. A very cheap fix and I hate to think what a service call would have been. Danby ph # is 800-263-2629.,
Dec 08, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler doesn't cool
you need to turn the temp. setting all the way up,use a rag to hold the fan,now see if the compressor. is running,let me know-mike
Jul 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Refrigerators Logo
1,185 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
