I blew out the tip and the water intake with my nail gun air compressor. Tried the tip first without any results. After I tried the water intake, hot water started to drip from the tip. Worked fine afterwards. Like other people have stated, water will spray, so make sure you cover the inlet and outlet areas with a towel. Their is a second outlet that is a piece of rubber that drains into the back of the water storage area. It points down and is ment to drain back into the water holding tank. Hot water could spray onto you hand after using the compressed air so be careful.
SOURCE: My Keurig coffee maker is
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
SOURCE: keurig B70, the my k cup , weak weak coffee !!!!!
It is best to take it to the store you bought it from and have them fix it and watch or replace at no cost to you. Tell the store what they said to you and have them show you how to do it. If you work on it and break it you own a broken machine. Hope this helps.
SOURCE: I have a Keurig B40.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
SOURCE: I have a Keurig b3000.
You probably have some scale deposits on the water coffee valve. You have 90% chances to fix the problem by just descale the machine even repeat twice with following instructions.
http://www.fixya.com/support/r5544114-keurig_home_brewer_instructions_de
In case that the [problem insist then the only way remains is to disassemble the machine and remove the valve and clean it manually from any scale or dirt that have blocked it from completely close.
