Bandmaster head volume is low and distorted - Audio Players & Recorders
  • 1,512 Answers
Hi Joanne
Check that you do not have a faulty quaddy or speaker lead first. by plugging the head into another box. If it is distorted on another rig, then you have a fault in the head. This can be a number of things, least to say that it will need some electronic repair work done to it. I suggest you take it to a guitar amp repair doood for a look. Sorry I cant actually fix it for you in the medium, but is will need some expert attention, so advice is all I can do.,
regards
Robotek
Posted on May 02, 2008
At low volume it is fine after you get to about 20 on the volume it starts to crack,pop and distort very bad what is making this happen
Your speakers may say 350 watts but that is the peak wattage at which they blow up and not a wattage they can sound distortion free at. Look for the RMS wattage which is probably around 40 watts. If you look at the specs on your receiver you will see it will put out a maximum of about 50 watts but the distortion on the receiver is above 1 percent at anything over 22 watts. That means they are going to start distorting at around half volume. The other thing you might check for is a impedance mismatch between the speakers and the receiver. Is the receiver set up for an impedence output of 8 ohms but your speakers are 4 ohms impedance.
Aug 23, 2015 | Kenwood KDC248U CD Car Stereo Receiver...
Low output with high volume
sounds like distortion is being caused by trying to amplify a low volume level from the input device. try putting the ipod volume at a medium level and try again to see if the distortion goes away/reduced
Dec 23, 2013 | Pioneer Avic-940bt Car Navigation Cd/dvd...
Subwoofer distortion with low volume
We need to know what the amp is and its model, what the speakers are, what the enclosure is.
Jan 18, 2018 | Rockford Fosgate Audio Players & Recorders
Camcorder won't record or playback,has distortion and low volume.Is it just real dirty?
Try to find a video cam ,,head cleaner,,at elonric s store ,,find online,,,try cleaning the heads down in there with alcohol and a q tip,,,also,,good luck,,but thats what it is just dirty,,
Dec 23, 2011 | Quasar VM-L152 Camcorder
The cheats of bandmaster
hi,
if you're looking for cheats in a game i'll suggest you visit www.cheatcc.com, do a search for your game and get the cheats and walkthroughs, i've done that a couple of times, have fun.
hope this helps
Jul 08, 2011 | Computers & Internet
I have a pair of kicker cvr 124 with a kole 1500 watt amp that is bridged to the woofers. the amp is 385 rms at 2 ohms where should the gain be to get the most power without distortion.
When setting your gain you want to set the gain high usually between 75% to 95%. if the gain is low than turning up the volume on your radio will only amplify the distortion coming from the under powered head unit. By turning up the gain you are maximizing the signal that is amplified coming from your head unit
Mar 20, 2011 | Kicker Car Audio & Video
I installed a Pioneer DEH-P800PRS head unit and 4 Kenwood KFC-1662S speakers in my 2003 Dodge Dakota extended cab truck. I used a Kenwood KAC-5204 2 channel amp connected in parallel. Sounds good at lower...
Hello.... sorry to hear about your problem. Bass is the ultimate evil of coaxial speakers. You have a couple of options here, and this is just my professional opinion because I do not know what your lifestyle details, such as truck space needs, type of music you listen to, budget, etc. If you are looking for alot of bass, the best bet would be to use 2 external amplifiers, 1 for the interior speakers, and 1 for a subwoofer. You would then need to purchase an electronic crossover. With this setup, you can remove all of the low frequencies from the coaxial speakers and put them where they belong, with the sub. You will gain EXCEPTIONAL clarity and a very high volume before distortion level. Again it will depend on what your budget is and if you are willing to compromise on some cab space. The only other option you have at this point is if you are wanting to play your music at high volume levels, you will just need to reduce the bass level as you increase volume. I hope this has helped. Good luck with your venture!!
20 year car audio/video installer
Bay manager
Mar 16, 2011 | Pioneer Car Audio & Video
Vibrato will not go slower than 4 on the speed knob,70's bandmast
The schematic for the Bandmaster does NOT show anything regarding "vibrato"... they DO have "chorus".
Chorus normally involves higher rate vibrato and it is possible they don't have the control scaled very user friendly and not all of the rotation of the control is effective.
Finding the exact schematic is important to analyzing the problem. and while I can find a "Fender Bandmaster" schematic I have a feeling it is not the right one. You might post an exact model number.
Dec 03, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Sound of the recording after burnt to a cd is very low
adjust your top knob which is called the gain, this will allow the incoming signal to be muchlouder depending on where you set it , the bottom fader is for playback volume and mixing and you should also a avolume control for your head set , follow also the recording instructions in your manual for optimal settings , there,s no reason that your recordings should come out with low volume other then your gain control being set to low , hope i was able to help , if i was please leave a nice rating ,sincerely glenn mayer
Mar 09, 2009 | Tascam 2488 Portastudio Multitrack...
81 people viewed this question
 Grubhead
Grubhead
