Question about Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Does it have a turner?
a television with a built-in digital tuner?
    President:
  • 2,712 Answers
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    Thank you for using FIXYA!
    IrishDruid
Rca 46inch tv everything work but the turner
I assume you mean "tuner". Could be a bad tuner, or possibly a voltage line to it.
Mar 27, 2014 | RCA Televison & Video
DOES THE SHARP T V MODEL lc46sb54u HAVE ADIGTAL TURNER, IF SO HOW DO YOU ACTIVATE THE TURNER
it has a digital tuner that also does analog channels. You dont need to active it. I fyou are trying to get the channels over an antena, go into the menu and do a auto scan for channels. Set the auto scan as "cable". If you are trying to get cable channels over 19 it wont work without a box. The digital channels are scrambled for cable.
Sep 09, 2011 | Sharp LC46SB54U 46 in. LCD TV
CAN I USE A DIGITAL TURNER TO GET THE TV TO WORK
If there is a COAX or RCA connection to connect a Digital Tuner, then yes, you could connect it. Assuming you can tune that TV on channel 3 or 4.
Oct 08, 2010 | GPX TVP7 Television
On my Olevia 42'' LCD TV, the tuner option in source stopped working. I now have HDMI, Composite, etc but no tuner. How do I correct the problem so that I can access tuner. Firmware ends in 060608B....
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Dec 24, 2009 | Olevia LT42HVi 42 in. LCD Television
How do I connect antenna for digital tv and program/scan for available channels
Hello Scott:
The unit must have a digital Tuner in it. This model do not come with a digital turner, so you are going to need a digital to analog converter box. And a High Definition Antenna. Once you have obtained these units go to your menu and select setup and switch to the the air mode and select channel scan.
Nov 26, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Digital built in turner
You'll need a better antenna. All the TV can do is show you the signal strength at the antenna input. If it's too low, only changing the antenna can help. This could mean simply adjusting the antenna position. You might need to replace the antenna with something larger or with a built-in amplifier. In severe cases, you might need to install an outdoor antenna to get a useable signal. With digital broadcasting it's all-or-nothing. A weak signal will either go undetected by the tuner or cause a blocky freezing (pixellated) display.
Mar 15, 2009 | Broksonic TV
About Sylvania TV
Hi malumbender,
Your tv dosn't have a digital tuner, in order to recieve OTA (over the air) digital signals you will need a Digital Converter Box.
Here is a link to a government website for coupons for the box. The coupons are for $40 off the purchase price of the box. There is a waiting list but they will come available as other coupons expire.
https://www.dtv2009.gov/
here is another site for antenna and channel line up.
http://www.antennaweb.org/aw/welcome.aspx
I hope this helps and please rate this solution, please keep in mind that a "Thanks For Trying" rating is negative.
Lone99star
Jan 26, 2009 | Sylvania 6615LFP 15 in. EDTV-Ready LCD...
I would ike t know if Sylvania LCD TV model LFP 6615 is has a digital turner?
CNET reviews for that TV says it only has an analog tuner only. No digital tuner. Sorry.
HDTV Turner
If your set has HD on it means set is HD Ready and you do not need Converter Box even if your only signal is coming from an antenna. Either a TV has HD or it Does not! And NO you cannot buy Parts to make your set HD.
Dec 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Emerson EWC19T3 19 in. TV/VCR/DVD Combo Logo
66 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
