Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Vtech not working
I have two lines 3 vonage connections. For one connection product is uniden 1869 which is working fine, other two connections have vtech devices. These are not working. Lights are there. Voice is cracking very badly , i can not hear anything, sometimes handset goes to searching mode
  • Kalmekolan Dec 02, 2008
    We have problem with VTech is that if we do any outgoing or incoming they are not able to hear our voice. but we can hear their voice.
  • Anonymous Mar 21, 2014
    just hooked up vetch phone and modem after move display on phone says connecting
  • 3 Answers
Have you tried putting in freshly charged batteries and registering the handsets to the base station?
Posted on Jul 05, 2008
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
May 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Need to connect directv from hard line to vonage.
I had vonage with dish network and was able to buy a phonex system for wireless connection. Worked great.
Mar 22, 2009 | D-Link Vonage-enabled Wireless Router...
No dial tone on headset 2
If you have a regular phone, then connect it directly to the Vonage phone router. Be sure and connect to the correct port on the router (mine has 2 ports, and I use both, but a single line subscriber would only hook to Line 1).
See if you get a dial tone with the standard phone hooked up (we are testing that the Vonage is good.first, then we'll deal with the Uniden phone.). If not, what do the light's indicate on the Vonage router? Have you subscribed to Vonage? Do you have a cable between your router and the Vonage router?
Reply back back what you find and I can help you more.
Jan 23, 2009 | Uniden 5.8GHz Cordless Phone
My in-laws have vonage telephone service with comcast internet, before they just had at&t with no problems. Now when they are having a telephone conversation the connection seems to cut in and out and...
With choppy audio and one-way audio, either party on the call hears the audio breaking up, or no audio at all. Dropped audio is when a call is in session and both parties are unable to hear each other.
  • From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes. From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes.
  • Reboot all of your devices (Vonage device, any routers and cable / DSL modems). How Do I Restart My Phone Adapter and Network Devices?
  • Ensure that your Vonage device is at least four feet away from any other device.
  • Ensure your Vonage device is in a well ventilated area to keep from overheating.
  • Ensure no file sharing, P2P applications, or large downloads are running while you are using the phone. These activities can use up most of your bandwidth, leaving little left for your calls.
  • Connect your Vonage device directly to your cable / DSL modem, if it is not already. If this helps the audio quality, then the problem is occurring between the Vonage device and modem.
  • If your Vonage device connects to another router and not directly to your cable / DSL modem, try disabling any firewalls or SPI (Stateful Packet Inspection) on that router. Click here to learn about firewalls and SPI.
  • If you wish not to disable your firewall, then you can port forward the Vonage traffic to the adapter. Click here to learn about port forwarding.
Wireless Routers and Cordless phones — If you have a wireless router and a cordless phone:
  • Ensure all wireless devices and cordless phone bases are at least four feet away from each other.
Home wiring — If you are using home wiring:
  • Ensure the land line has been disconnected in the Demarc box. Ensure the land line has been disconnected in the Demarc box.
  • Ensure there are no more than five phones connected through the house wiring. The signal fades as more phones are connected to house wiring.
  • Test with one phone directly connected to your Vonage device. If this fixes the issue, there may be a problem with your house wiring.
If you have made it through this checklist and you are still experiencing an audio problem, our first class customer service is available to assist you. Please have handy your account ID, phone number, name of your internet service provider (ISP), and model numbers for your Vonage device and any other devices in your network.
Dec 03, 2008 | Vtech mi6896 Trio Cordless Phone
Phillips faxjet connecting to vonage telephone service
Fax machines are ANALOG devices. Vonage is a DIGITAL phone system.
Oct 22, 2008 | Philips FaxJet 375 Plain Paper Inkjet
Connecting vonage vt2442
hi not sure if this problem is still there, with that device u may have to try a mac clone. have everything set up properly, and on the computer connected to the vonage go to the cmd prompt, enter 'getmac' and it will give u a mac address or try ipconfig/all and write down the mac address fro example it will say 00:12:3e:8d:ca:01 so write that down, then open an internet explorer page and empty everything from the address bar and type in 192.168.15.1, then a screen will pop up asking for a username and password., this is the settings interface page. router is both. then go to advanced set up, then ethernet options then u will see something about a mac clone. selct that the enter in the mac id u wrote down earlier than apply, now restart the whole system modem and vonage, then turn modem first wait for lights than vonage and wait for vonages power lights be solid green. then it should work.
it may not work in broadband is inactive or not enough speed to work sufficently. try that first :)
Sep 07, 2008 | Vtech mi6896 Trio Cordless Phone
No connection
deregister headsets and then run register again
Jun 09, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Base not able to connect to handset.
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
Dec 22, 2007 | Uniden 5.8GHz Cordless Phone
Vtech 5.8 GHz and says cant connect
Mine turned out to be not getting power from the surge protector.  Plugged it into the wall and it worked again.  If the power light is off to the base station it is not getting power and won't connect.  I know this is a duh, but I missed it.  Probably not what is wrong with yours.
Nov 19, 2007 | Vtech 5.8GHz Analog Cordless Phone
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
197 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
