GE Security Simon 3 Wireless Home Security System
Problem for GE Security Simon 3 Wireless Home Security System
Don't have the access code
By 9McCool on May 01, 2008
is there anyway of resetting the security code for this system. It works great, just can't shut it off short of turning off the power. We bought this condo from a foreclosure sale and can't locate the owner.
Thanks.
Same Problem
Aug 25, 2008
-   we purchased our home with this system, and do not have a code. try to reset it access denied. how can we deactivate it to set new code. thanks-   tweetygirl41
Jul 02, 2008
-   i dont know the code to my alarm have tried to use the manual but no luck-   cassiemolly
Jul 02, 2008
-   alarm code-   cassiemolly
Solution #1
posted on May 19, 2008
Somewhat Helpful)
Techsy
Rank: Guide
Rating: 86%, 9 votes
Do you mean the access code for turning off an alarm or arming the system before leaving? If so, NO. You would have to know the original code to even enter programming to change the access code. Contact your realtor and have them get you in contact with the previous owner. Find out the code from them. If they properly removed their code before moving from the house use the default code, 1234. Good Luck.
Was this helpful?
Yes
No
Solution #2
posted on Dec 20, 2008
Somewhat Helpful)
Daddydog007
Rank: Apprentice
Rating: 75%, 1 votes
Depending on how option 54 is set the default master codes are 123456, 12345, 1234 or 123. The default Utility codes (1-Dealer, and 2-Installer) are 654321, 54321, 4321 or 321. If you get any of these to work, you can follow these steps to reset the memory to factory defaults:
  1. Open panel cover and enter in code that worked from above.
  2. Unplug the transformer and disconenct the battery.
  3. Simultaneously press and hold - Cancel, ClockSet, and Minutes +.
  4. Restore the power to the panel with the battery while pressing these three buttons. The panel should respond "Hello. System XX OK"
  5. Release the buttons and plug in the transformer to the outlet.
Was this helpful?
Yes
No
Solution #3
posted on Oct 07, 2008
Somewhat Helpful)
althtnmore
Rank: Apprentice
call the security company (adt, brinks ) and they should be able to reset everything for you if you resign a security contract with them. After all the system is ment to be a monitored system
Was this helpful?
Yes
No
Popular Solutions for GE Security Simon 3 Wireless
Questions and Unsolved Problems for GE Security Simon 3 Wireless
Do you recommend GE Security Simon 3 Wireless Home Security System?
Answer
Answer
I set the new Simon 3 system with a 4 digit master code...but then when I try to add an access code... (More)
Answer
we have had a gemini security system but have not installed it. Then, the baby in the house pressed... (More)
Answer
Hi, The system battery is low, but I can't figure out how to replace it; it's not in the manual. I... (More)
Answer
how do you replace the battery for the vista 15pmt system. I have the low battery light
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Security Simon 3 Wireless...:
Top Security System and... Experts
Rank: Guru Guru
Solutions: 735
Experience: 30 Years of professional repair and design.
Ask Me
Find more Security System and... Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
