Question about RCA HD61LPW175 61" Rear Projection HDTV
Broken cable hook up
Is there any way that i can get my cable on through the television that i have without having to directly hook up the cable wire to the tv? my model of tv is and RCA model # mm36100 serial # 933310031
  • kbass84 May 01, 2008
    please help
    Genius:
  • 1,030 Answers
Sometimes if the tuner is not damaged then a technician can put it back on... the other option is to tune the channel through a vcr.. essentally bypassing the tv tuner and useing vcr tuner. hook the cable to vcr then using rca jacks yellow red and white connect it to you tv(if it has rca jacks ...most have them these days.. sometimes on front and sometime on back or even on the side.. tune your tv to that input(video 1 or something like that.. then using your vcr remote change channel...its not a perfect solution but it will save you the 130 buck most charge to repair that connector
Posted on May 02, 2008
I Have my RCA CABLE HOOKED UP INTO MY TV I HAVE A PICTURE HOWEVER I DON'T HAVE ANY VOLUME AT ALL
How do you have it hooked up? RCA cables, HDMI, DVI, etc...
If you're using RCA cables (usually red, yellow, and white) check and make sure that the audio cables (red and white) are plugged into the correct sockets with corresponding colors. If you have properly connected the cables and your issue persists, then you might have faulty wires (might have a pinch which could have broken the wire through the inside) try again with different wires and see if it works. if it still doesn't work try pluging your RCA cables on different sockets (TVs usually have more than one component sockets)...make sure your red and white wires are on the same component # as the yellow wire.
Feb 16, 2014 | Emerson LC391EM3 39 in. LCD HDTV
Advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
Brought a GE model 27gt722 tv...can not pick up all channels on cable. Usually once you hook up cable wire to tv cable is automatically on ..at least that is how it was on old tv
Depending on the cable company, some like Comcast have gone mostly digital meaning when you connect the TV directly to cable without a cabe box you will only get around 35 channels. The only way to get around that is to get a cable box. If you have Comcast service already they offer what they call a DTV cable adaptor which will allow you to get most cable channels. These DTV adaptors in most areas are free for the first two per household. I hope that helps : )
Jul 25, 2011 | GE 27GT722 27" TV
When hooking amp directly to battery, you hook battery hot cable and power hot cable then hooking ground cable up the ground cable becomes hot and pops the fuse
your amp is bad. you should have a 12v, ground, and remote wire. if these are hooked up correctly, your amp is more likely broken, and needs to be repaired or replaced.
Jan 30, 2011 | Car Audio & Video
I just need the basic wiring instructions for hooking up the direct tv, an x box, and how I'm suppossed to go from tv to reciever and the monitor out cable. I have a samsung txr3079wh flatscreen. I also...
Connect the Direct TV and the Xbox directly to the television by their respective video cables.
Then connect their audio cables to the audio inputs on the receiver.
This connection method does not require use of the monitor out terminal.
Sep 09, 2010 | Pioneer VSX-818V-K Receiver
MY TV CONNECTOR AT THE BACK BROKEN OFF
you can hook it up thru av input..what i mean is the red white and yellow wires hook wires into the OUTPUT on box and the input on tv then change tv to the input u hooked them to..for example if u hooked them into av1 then turn tv to av or hiy input on remote
May 26, 2009 | Sharp 25N-S100 25" TV
RCA TV
Hook cable directly to television ( no box ) , Then autoprogram the set if you still have the problem replace the tuner it is about $30 rebuilt from Tip Top tuners.Do not attempt if you dont feel comfortable soldering precisely. IRIONS TV & Electronics www.Irionstvshop.com
Feb 21, 2008 | RCA F27628 27" TV
RCA HD61LPW175 61" Rear Projection HDTV Logo
701 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
