Can you please give the make and the model no. so that i can help you fix it.
Comments:
May 01, 2008
- Hi,
Sounds like maybe the chips on the cartridges aren't making proper
contact. Have you tried removing the black cartridge and reinserting?
How
long did it take you to replace all the color cartridges? If it sat
uncapped for very long, the black may simply be clogged. Often a few
drops of Windex with Ammonia D (not the lemony stuff!) on the
purge/park pad will do it.
With the lid up turn it on, and as
soon as the heads are unparked pull the plug. Very gently, slide the
print head out of the way. With an eyedropper, put a few drops of
Windex with Ammonia D on the park pad, enough to make it obviously damp
but not overflowing. If it is all gummed up, you'll need to clean it.
In that case look here for more detailed instructions: http://www.polyphoto.com/tutorials/PrintHeadCleaning/
Rating Locked! (?) lilysee1 has rated this solution as Very Helpful
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a...
(More)
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a very old printer ?
Thanks
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not...
(More)
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not necessary)for my home that at least does decent photos for my personal use. Any suggestions?
lq2180 when print few lines, the printer pause light on, press pause button print again, than pause...
(More)
lq2180 when print few lines, the printer pause light on, press pause button print again, than pause again, need to stand there and keep pressing pause light
