Question about Toshiba Satellite A105 Notebook
Overheated and now won't load
It overheated and now won't go past the windows start up screen. It WILL go to the Windows screen but then I get the blue kernal of death and it loops around to restarting. I tried to use Ubuntu to get my docs of but it won't boot from that drive. I replaced the DVD drive and still get nowhere. What do you suggest?
  • 667 Answers
Hi teach- It sounds like a problem of thermal shutdown. This is a very common problem with Toshibas. You can try sucking out all the slots as much as possible with a vacuum cleaner or shop vac. The more powerful the better. Hold them there for a while and try to get as much dust and dirt (or hair if you have a pet) You may very well have a clogged heat sink. You'll have to take off the bottom if it comes to that. Try the first part of this solution. Let me know what happens. If it fixes it great! If not we'll proceed from there and I'll be here to help you out. Thanks.
Posted on May 02, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton May 02, 2008
    Did you try what I suggested> How do you know that the heat sink is not clogged and causing the problem? The suggestions we give you are the most obvious things that can be causing the problem. If you've tried EVERYTHING I suggested I mentioned I would be happy to help you further. Not all problems can be solved on the first solution. That's why it is better if you don't rate until we/ve tried several things. I wouldn't just tell you to try one thing and if that didn't leave you hanging. My only goal is to solve your problem. Many peiple are surprised to see the amount of dust than build uo inside their unit. Is there some reason that leads you to believe my other suggestion will not help your problem? I only want to solve your problem. Let me know please. Thanks.
My laptop is lit up but cant go any further
Wdk, Try starting up in safe mode and use system restore to go back to an earlier date when PC ran OK, an update or virus may have corrupted the start up. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Windows is loading files then blank screen
My Toshiba satellite cannot load anything at all Windows 8 and Windows 8 1
Aug 27, 2016 | Toshiba Satellite Computers & Internet
Toshiba satellite problems L775 can't get past "windows is loading files"
First restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 03, 2013 | Computers & Internet
Windows 7 won't load
try going to the bios screen and re installing the windows
Jan 31, 2013 | Acer Aspire One PC Notebook
Laptop won't load past windows start up page
Keep pressing F8 before Windows logo and there will be an option to rset, but you need a recovery disk.
Jan 13, 2013 | Dell Latitude E5400 Laptop
I have a Samsung NP-RF511 S04AU That won't start past the startup screen. I don't want to lose what is on my C drive can someone please help. I am running Window 7
Several things you can try.
Roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
In Safe Mode try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 01, 2012 | IBM Lenovo ThinkPad T61 Notebook
My medion akoya laptop won't load past intel screen
This is a hard drive issue or windows have corrupt files, if you have the installation disc try and reload the operational system, if no change! have the hardware checked out at a computer repair store.
Apr 08, 2012 | Medion Computers & Internet
My Acer Aspire one won't go past windows xp loading page but i can get on through safe mode, how do i get passed windows without it restarting?
go into safe mode then restart
when it turn back on press f8 buttonrepeatedly until the option screen appears select last known configuration option you should get in
May 30, 2011 | Apevia Aspire One A150-1777 Netbook
Try Safe Mode.Disconnect every device (Mouse also)
Hit F8 at very beginning until you get a list of options select Safe mode and check if Windows starts.
then try step by step confirmation option.
say yes to every request until freeze: last driver you accepted to load is the culprit.
Remove it in Safe mode using Start/Run/Msconfig
Dec 26, 2008 | Computers & Internet
This can be a memory, or disk drive failure, or something on the mother board. Try to start in the safe mode to see if there is a display of the error that is occuring.
Jerry G.
May 01, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
