Teac CR-L600 Receiver Logo
Posted on Aug 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a teac crl600 and want to connect my ps3 via the optical cable. However not sure if possible as looks like an output not an input?
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Aug 18, 2010
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2766069
Points
24828
It is an output. No digital inputs.
I need help with using my TEAC DV-200 speakers as an external audio source for my smart tv using the digital optical cable connection.
Are you using just the speakers (designated DV-200) or the full
Teac DV-C200 DVD Audio/Video Micro System?
You would need the digital optical cable out from the television to a digital optical cable input on the DV-C200 system. Digital is not like a normal signal in the way that analogue AM radio and FM digital radio differ. In fact it is more like DAB radio.
The best thing to do it Google the manual for the television and the speaker system and read the input and output specs.
https://www.google.com/search?q=TEAC+DV-200+speakers
Aren't getting sound from Denon AVR 788 hooked up to PS3 via optical
Did it work through cable leads.?
Could be an output problem, could be an input problem at the PS3, could be a dicky lead.?
Rule out the 1st 2 by testing another piece of equipment through that lead or into the PS3.
If something else works through the PS3's optical input AND through that optical lead,
then it must be a problem with the optical output on the Denon.?
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
I have an LG DVD Reciever HT462 which i want to connect to my PS3. My PS3 is all set up correct as I have spoke with Sony. I have the PS3 connected via a HDMI cable to my TV and an optical cable running...
It would appear from what you have said that you have everything connected properly. Maybe a silly question, but make sure you select the digital input on your LG to get the sound from the PS3. If there is still no joy, unplug the optical from the back of the LG unit. Look at the end of the Optical cable that should still be connected to the ps3. Is there what looks light a red light there? if so it means that the optical is getting to the LG system and the LG sytem's digital in port is Duff. If there is no "Red Light", unplug it from the PS3 and look directly at the optical out port on the ps3. Is there a Red Light there? if there is, you need a new optical cable. If there is no red light, you need to enable the digial output on the ps3. If you have and it's still not "red". the optical port is duff.
1helpful
Connect teac ar 600 amp to digital optical output on new TV
Should be easy if it has a optical input. If not you will need a digital to analog converter with a optical input. Some have optical, some coaxial some both. Do a web search. I know they are out there, just not sure how much.
2answers
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
6answers
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
