Question about Refrigerators
Warm fridge freezer is working but frigde is warm
  • DavemanX Jul 05, 2008
    The freezer part is not defrosting correctly and ice is accumulating. The fridge part is just not as cold as it used to be. Last week I started to notice the fridge part getting some water leaked inside of it.
    What do I do? How do I fix this problem? I mean, I'm afraid to eat my food without getting sick, it's going to spoil.
  • icemanx Jan 30, 2009
    The refrigerator is only just a little colder than outside air temp and a lot of ice in the freezer compartment.
  • 828 Answers
Need additional information as to make and model number. Check for frost build-up in the freezer, is the fan operating in the freezer?
Frost build-up in the freezer compartment will stop air circulation and the freezer will appear to be working but will not be at its design temperature. If this is your problem then it is in the defrost circuit.
Posted on May 02, 2008
Fridge does not cool, serviceman has replaced both freezer and frigde compartment fan motors, also has replaced the thermostat but it still does not work , Fridge if a frost free one
you have blown a defrost element in the back of the freezer have it replaced and it will work fine
merry christmas
please take the time to rank this advice
Dec 02, 2010 | Refrigerators
The frigde is turned dow but still freezing all
your cold temperature control is bad, not shutting the unit down when the temperature is correct. needs to be replaced.
Mar 23, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Have a dometic ndr1292 side,freezer works fridge at 60 degrees
Try to defrost it. unplug fridge and place a box fan in front blowing at it. keep the frigd controls in the midle range as well as the freezer control
Sep 05, 2009 | Refrigerators
SIde by Side Kenmore -- Freezer is fine Fridge Is Warm
the freezer needs defrosting or the evaporator fan has failed and is not blowing air into the refrigerator side.
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge warm, freezer fridge temp
The adaptive derost control has gone bad a very common issue. It will work a couple of weeks before its back to its frosting over. It just plugs in but to get to it you must remove the controls at top of frigde section in the back right corner held in by two scewrs.
Mar 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Feb 18, 2009 | Kenmore 62232 / 62234 / 62239 Bottom...
Warm fridge
Hi and welcome to FixYa,
Initially, this normally would point to the fan not spinning. The function of the fan is to draw the cold air from the freezer and force it through the vents to the refrigerator area. Even having said this, the fan is activated by the logic controller based on the the thermostat setting of the refrigerator and condition of the door (it must be closed).
To check:
  • fan - open the door, locate the door switch, press on it, light should go off, fan should kick in within 60 seconds. If not, faulty fan, fan relay, or controller. Alternately, you can measure the continuity of the motor's coil and or if there is voltage going to the terminals of the motor;
  • thermostat refrigerator side, you would need to use a continuity tester or have an electronics shop perform this. At room temperature the reading should be low, and should go high when the probe end is submerged in a glass of cold water.
Alternately, it may be the vents, flaps or vanes that are stuck, clogged, blocked and hence no air flow from the freezer to the fridge side.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 12, 2008 | Refrigerators
Tempratue problem
air from the freezer fan, means the sensor- temperature control circuit is working right, it is trying to cool
there has likely been a leak from the system and there is not enough coolant left for the compressor to compress anything.
a GOOD repair guy
will have a pressure pump/gauge and test for leaks through the fill nozzle, repair them and regas the fridge (provided it is a non-CFC r12 fridge) without removing it from the home,
a not-so-good repair guy
will not
Sep 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerators Logo
337 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
