Question about IBM ThinkPad T21 Notebook
No Power I checked the power supply with a meter and it is ok. The computer won't power up coul it be the mother board that fried?
    Scholar:
  • 144 Answers
Hi Kmantapeman,
yes it could be the motherboard problem but what I would like to test here first is remove some component one-by-one and try to turn your notebook on and see...(see mean any noise or light come up)
1.remove battery
2.remove harddrive
3.remove memory
4.if possible remove cdrom
5.anymore incase you have
if nothing work then its a motherboard problem.
goodluck,takecare.
Posted on May 02, 2008
Computer power supply does not work
Need to know how old a computer it is as over the years the power supplies' use different methods of starting.
On newer computers the power supply is connected to the mother board by a 20 or 22 pin connector. The power button on the computer is just a momentary switch to start the computer. Make sure the large connector is firmly seated in the mother board. If you are comfortable with doing that have someone else check it. You do not want to damage the connector or mother board. You need to have some sort of anti static device conntected to your body to avoid any static discharge that could damage the mother board.
Feb 09, 2014 | Antec TruePower Quattro 850-Watt Power...
Dell Vostro 220 won't turn on. Checked plug with volt meter and getting power to power supply. Back green light is illuminated. Could it be the mother board?
Usually that happens when there is a power spike and the internal resistance gets fried. It's easily replaceable by anyone with medium to high technical skills but I recommend sending it to be serviced (especially if you're in warranty). This resistance's purpose is to protect the motherboard (it fries so that the motherboard doesn't) so don't worry, it's nothing major.
Sep 23, 2013 | Dell Vostro 220 Desktop Computer
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
Not able to switch on the mothere board. Green led on the board glows but the system is not powering on.
1. Check the mother board user manual 1st. To see how to properly install this mother boar to your PC cabinet or tower.
2. Check to see if you have the power from the power supply correctly connected
3. You may not have the proper watts or power from the power supply to power said mother board.
4. check the mother board battery it may not have proper voltage it should be 3.9 volts or more with a voltage meter check.
usually a 2025 button battery on the board
Feb 02, 2010 | Intel Computers & Internet
While running the computer all of sudden switched off
If your PC SMPS is ok then your PC motherboard has been faulty. pls checked it from service center.
Oct 13, 2009 | ASUS P5GD2 Deluxe Motherboard
My television quit working after a storm, it wasn't even turned on during the storm. the power on the set and remote does nothing. but it makes a sound when plugged in like it is turning on then nothing...
Ok, this was a direct hit in this case and you will defiantly need to replace the power supply board in this unit. the first thing that will happen during a direct hit is, the surge will run threw the power cord and travel threw the entire power supply circuitry, frying all circuits. this includes the main mother board as well. I recommend replacing the mother board and power supply board as well. this will restore your set to its original operational value. The mother board is commonly called the main control board.
please rate and god bless:)
Apr 02, 2009 | JVC HD-52G886 52" Rear Projection HDTV
No power
Just open ur P.C cabinate and look when the Power supply is on in ur mother board then there is a green light in ur Mother board ; is it on ??
If the LED is on then I hope ur mother board is ok yet.
Then I think there is some connection prob on the pushing button on the cabinate.
Check it if it is not then u have to replace ur mother board.
Jan 02, 2009 | Gateway 3200XL PC Desktop
HP Pavilion a1000 won't power up
usually the brown outs fries the mother board when the power supply fries on these computers
Dec 22, 2008 | Nikon N75 35mm SLR Camera
Optiplex GX520,270,280,755,745 ONBORD COM PORT AFTER DAYS WILL FAULTY
A surge protector stops power surges from eskom etc. from fryin your mother board and power supply. when the power goes off sometimes its just a phase . when all phases are off and the power comes back to all Phases instantly at a strong output this can fry your mother board or damage your power supply . surge protector keeps the power at one level even if it isnt , make sense? Also see UPS.Lightning can do the same effect too
Jan 18, 2008 | Dell OptiPlex GX520 PC Desktop
IBM ThinkPad T21 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
