I have a JVC av48wp30 tv with a convergence problem. I have read about changing the 2 stk392-110 ICs. Do I also need to change the resistor? Also, where can I get the schematics and instructions on how to make these fixes?
  • 8,617 Answers
Go to this link they have replacement Convergence ICs and they provide free instalation instructions with pictures plus free on line tech support so you can do the repairs yourself.
Posted on May 02, 2008
Double faces with red 'halo' around people...after TV 'popped' and went off then back on.
Replace the convergence ICs and resistors. You can get the JVC repair kit called the AV48WP30 - AV65wp30 convergence repair kit from www.tvrepairworld.com which contains the ICs, Resistors, and the CD with repair instructions.
May 25, 2011 | JVC AV-56WP30 56" Rear Projection...
The tv is blurry it seems the colors are not lining up.
Thats a common problem caused by failed convergence ICs. You can get the AV48WP30 -AV65WP30 convergence repair kit from www.tvrepairworld.com the kit contains the ICs, Resistors and the CD with step by step instructions for the repair.
Aug 15, 2010 | JVC AV-56WP30 56" Rear Projection...
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
Convergence is off on jvc av-56wp30
You will need to install a convergence repair kit which contains two Convergence ICs STK392-110 and then the associated resistors as usually a JVC will Need at least 1 or 2 of the resistors when the ICs fail. You can get the kit for your model at the following link which has the IC and all the resistors plus step by step detailed instructions on how to do the repair. This kit fits your model JVC
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Jun 18, 2009 | JVC AV-56WP30 56" Rear Projection...
Was convergence problem now dont know
often on that model the DCU which is on that same board is where the problem is especially if new ICs and resistors dont fix the Issue. The DCU is the metal cased unit which is next to the Convergence ICs heatsinks
Mar 14, 2009 | JVC Televison & Video
Model# AV48WP30 Picture show double vision. Colors cant be adjus
you need to replace the convergence ICs and associated resistors you can get the repair kit at the following link for your model which contains the two ICs and all the feed resistors plus step by step instructions with detailed photos how to do the repair. Heres the link to the kit for your model.
Mar 05, 2009 | JVC AV-48WP30 48" Rear Projection...
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
Aug 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Convergence
did you replace the convergence resistors with the ICs? The resistors often get increased resistance when the ICs go out and if they dont get replaced you can have a next to impossible time adjusting the convergence properly, as they have to be within 5% tolerance. You can get the resistor kit for your JVC at the following link. Its Called JVC convergence resistor kit #1. Heres the link.
Jul 01, 2008 | JVC AV-65WP74 Rear Projection Television
Convergence chips
The convergence IC or in a sense ,amplifiers and the resistor are output resistors... if they are burning up the current going through them is spiking too high... TO me this is an indication that the "convegence yokes" are shorted. These are coils around the tubes that control convergence. I would suspect maybe that these are shorted to ground somehow. This is my first guess for this problem
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
