Question about Philips 42PF5521D 42 in. HD-Ready Plasma Television
Need settings because of rubbish picture
Hi, I have a 42" plasma tv, model number: 42PF5521D/10
The problem i have is that i cant quite seem to get the settings right for any picture through scart. i keep getting dead 'blue' pixels in the top left hand corner of the screen after 20 minutes of watching anything, it has slowly got worse but it started not long after i got the tv, so i tried as best i could using a 'CARS' dvd with the THX Optimizer to set the picture settings but it hasnt helped, and when i watch football or snooker, the green of the pitch or table seems fuzzy and pixelated, so I was wondering if you had any idea of the best picture settings i.e brightness,colour,contrast,sharpness,colour temp. any help would be great and hugely appreciated.
If you need to know, i am sat 8 feet away from tv, the tv is opposite the window (facing it) but mostly i have them drawn if too bright, my room is usually well lit.
I thank you for your time, Phill
  • hypdrive May 02, 2008
    thanks alot for your help, i appreciate it and it has cleared up a little, i guess as you say, it must be the sky box,
    thankyou again
  • T5BNC Apr 15, 2009
    Hi Interestingly enough i have the very same problem. I brought the same T.V in march 2007. On the left hand side of the set i am getting what i call Blue mist, I assume it is dead pixels after reading this post. I have tried everything i.e XBOX 360 via HDMI, SKY via scart, DVD via scart. and am getting the same problem, which is very fustrating!!
  • 476 Answers
There is no right or wrong setting for the TV, but I find the following give about the best results:
  • Contrast - 65 maximum
  • Sharpness - 2 maximum
If these are set any higher, the picture becomes very grainy, particularly around defined shapes.
  • Contrast + - OFF
  • NR - ON (If applicable)
These settings will need to be changed for each of the following:
HDMI 1& 2
  • EXT 1, 2 & 3
  • Analogue tuner
  • Digital tuner
The problem you describe, is usually with a satellite or cable box.
Unfortunately, there's nothing much you can do about the dead pixels, but the settings may make them less obvious.
Posted on May 02, 2008
  • David Simpson May 03, 2008
    There are a few settings you can change on the Sky box too.
    Go into the picture settings menu - Services ---> System Setup ----> picture settings
    Make sure that Picture format is 16:9 (1st option)
    Also, make sure that Video output is set to RGB, NOT PAL.
    RGB gives a much more stable picture than PAL. You may need to connect the Sky box to scart 1 of the TV to get any benefit.
    If you switch back & forth between PAL & RGB you will notice that the shimmering around the Sky menu screen disappears.
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Mar 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
My samsung tv model number is sp50L7hx it's 6 years old, when I turn it on it's a not really nice picture just nice sound, after 2 hours the picture is off just sound .... after I was switch off TV...
This is a plasma screen T.V. and doesn't use a lamp. You are probably correct in thinking it's the T-Con board. This board is sometimes a pain to get it. When you get to the board, look up the board number on the side on e-bay or other internet resources for the lowest price if you're comfortable changing it yourself.
Jun 19, 2011 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Tv wont come on , and green light keeps flashing, tv model 42pf5521d/hd
Hallo! You might have a power trouble. Open the rear cover and take a look over the power board- that's the board where goes the alimentation cord. Look if there are not inflated the electrolytic capacitors, if yes, you must change them with the same type. Be careful with the polarity of the capacitors- you must solder them the same way as the old ones were.
May 13, 2011 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
42" plasma tv problem
Hello, If you are referring to the actual shape of the prongs coming out of the tv plug(refer to figure): prs1-6980390t98.jpgif the prongs look like this, you will have to acquire an ac adaptor for your TV, this adaptor you can locate at any radioshack store, and sometimes it's called foreign ac adapters for US use.
or simply look at the radioshack webpage, it should be listed under ac adapters.
Apr 13, 2010 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Hi. My Philips flat TV will not show any picture
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 20, 2009 | Philips 42PF5521D 42 in. HD-Ready Plasma...
No picture or sound on LG 42" Plasma
Hi Craig,
Your Tv has a 1 year warranty, you should contact Customer Service as soon as possible. This is the number in the USA 1-800-243-0000
If needed this is the Global Site. www.lge.com/products/category/list/tv.jhtml
Enter your country then click on Support for the Service Number.
If this helps please rate this solution as a FixYa.
Lone99star
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Issue with LG Plasma tv model # DU-42PX12X
Another "same probelm"
My set has encountered this magical 50/50 split screen and it seems to be quite a problem since I am not the only one researching this issue. LG was of no use because of course it is just out of warranty. Any solutions on fixing this or am I out of money in buying a new plasma?
Jan 27, 2009 | LG DU-42PX12XC 42 in. Plasma HDTV
Philips 42pf5521d - no picture, blinking green light
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting the number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Aug 17, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Philips 42PF5521D 42 in. HD-Ready Plasma Television Logo
415 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
